[SOLVED] PC Crashing, Please Help
Aug 26, 2020
My friend has this pc, and it keeps crashing when playing games (Counter Strike GO, Rainbow Six, GTAV, Watch Dogs 2) for around 20 minutes. It wouldn't shout down, the screen and the CPU unit is still on, but the screen would be just blank. Also the audio became like static stutter or something like that, then, we cant do anything but force restart the PC. Any idea what may have caused this ? I have underclock the GPU and its still the same, temps are OK (~75'C Max), Ram is OK ( i check on windows memory diagnostics), storage is also OK, we also have recently replaced the thermal paste on both the CPU and GPU.
Here are the specs :
  • Intel i5-2500
  • Biostar RX470
  • Kingston HyperX 1x8GB DDR3
  • HGST 512GB
  • Monitor : Lenovo D186wa
which power supply is it? brand and model
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
use ddu uninstaller and reinstall the latest graphics driver from amd.com
How hot is the CPU getting?
update the BIOS of the motherboard
check the...
clean boot
check the GPU in a different PC
