Hello!
Around a month ago now, I built a custom built PC with new components ordered online. Ever since building it, I have been having issues constantly with the computer. Usually, it starts with a game repeatedly crashing (this happens randomly from 10-60 minutes into a game, and happens faster with some games compared to others). When the games crash, I usually get the following errors in event viewer:
All of the errors are event ID 0 and event ID 13.
Usually, after anywhere from a few hours to a day or two after these games start crashing, I will see the computer begin to start having BSOD errors. For the errors I got to today, here is a link to the minidump files on a OneDrive
Something to note about this BSOD is that sometimes, instead of seeing the blue screen, I would simply get a "HMDI no signal" message on the monitor and the computer would restart without me seeing any blue screen.
After getting these errors, I first assumed it was a driver issue. I have since tried several different older drivers (and the newest driver) by using DDU to completely uninstall the driver (with the internet disconnected and fast startup turned off) and then extracting and installing the new driver from a file I had downloaded beforehand. This typically will fix the problem for a few hours to a day or two, but then the problem will return again.
To try and rule out a hardware graphics card problem, I also got a 1070 card from a friend (who said it worked fine on their computer) and tried it. It worked for a bit and then the same problems started appearing after about a day.
Now, specifically for the errors today, I had a few more interesting problems appear. When it started BSOD today, I booted into safemode and tried running DISM health restores and SFC\scannow. In previous cases, I've also run these every time and they have found no issues, but this time they did find and fix a corrupted file (which is interesting and confusing)
Here is the file from the restore:
From there, I also noticed that one of my errors in event viewer mentioned "BITS" error which were these:
From there, I looked into the BITS service a bit and found a method of fixing it. So I ran a fix on the BITS service and it said it failed to fix it.
I'm not entirely sure what this means, or if it fixed my file/service to be honest. However, after doing this I still was getting the BSOD errors.
I decided, since I was getting the BSOD right away, to try taking out one of the ram sticks. In the past I had run windows memory diagnostic and had no errors, so I had potentially ruled it out as the errors did not seem RAM related. However, after removing my RAM in slot 2 (the other stayed in slot 4) my computer started up without BSOD! I then launched a game that would normally crash, and it ran for about 5 minutes with no issues (this doesn't fully rule out the game crashing issue, but it seemed promising).
Based on this result, I shutdown the computer and tried swapping the other RAM stick into slot 4. Once again, the computer booted up fine with no BSOD and I ran the game with no problems for a few minutes. After that, I tried both RAM sticks in again (this time they are swapped which is where compared to earlier, but they are still in slots 2 and 4) and the computer immediately BSOD rebooted on startup. I rebooted and tried again and the computer this time the computer booted to desktop. So I tried to launch the same game I was using before, and the PC crashed on the games main menu within a few seconds.
Now I am very confused. The errors seem so scattered and varied to be only a RAM issue, and the issue seems to be related to the motherboards slot possibly? I am going to run memtest86 now to fully check the RAM as best I can.
My questions are:
1. Does this look like a RAM issue?
2. Does it seem like something that could be caused by the motherboard slot, or even the motherboard itself?
3. Does anyone know if memtest86 will be able to find an issue if it is with the motherboard slot?
4. Is there any recommended number of passes I should do with memtest86 for this?
5. If anyone has any other ideas/insight into the problems I'm more than open to more thoughts as well
Sorry for asking so many questions, but I have been struggling through this for a while now and truly appreciate any help anyone is willing/able to give![Smile :) :)](/data/assets/smilies/smile.gif)
Here are my PC specs as well:
Processor: AMD Ryzen 5 4500
Motherboard: Asus PRIME B550M-A Micro ATX AM4
RAM: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Storage: Kingston NV2 500 GB M.2-2280 PCIe 4.0 X4 NVME SSD
GPU: GeForce RTX 2060 6 GB
Power Supply: NZXT C550 550 W
Operating System: Windows 10 Home
![image.png](/proxy.php?image=https%3A%2F%2Fmedia.discordapp.net%2Fattachments%2F1157789410465693716%2F1159884011213172846%2Fimage.png%3Fex%3D6532a529%26is%3D65203029%26hm%3D31d7ef1e790914400f5350c4b8d4e8e2ee47e6dba9e6b0d48ceec344efc965e3%26%3D&hash=aa40b1d89b82f155652f12ed5a73e0a5)
![1drv.ms](/proxy.php?image=https%3A%2F%2Fp.sfx.ms%2Ficons%2Fv2%2FLarge%2FNonEmptyDocumentFolder.png&hash=25e0186405720da91aa7969cc54f7273&return_error=1)
![image.png](/proxy.php?image=https%3A%2F%2Fmedia.discordapp.net%2Fattachments%2F1157789410465693716%2F1159886957648826488%2Fimage.png%3Fex%3D6532a7e8%26is%3D652032e8%26hm%3D10b6746ff54d29780bdeec8a834557c2dce0d4b1596b5540dcb4da37fdb89eed%26%3D&hash=a64650d6aeb8ae341a3795dece46975d)
![image.png](/proxy.php?image=https%3A%2F%2Fmedia.discordapp.net%2Fattachments%2F1157789410465693716%2F1159886873032925225%2Fimage.png%3Fex%3D6532a7d4%26is%3D652032d4%26hm%3Da5c8d1eacd078bdcf7a7b70d5527094b81413f6c9017e00cee8b9ca7ba2ad166%26%3D%26width%3D1200%26height%3D455&hash=f3b089c50bb3d3b168bdd6e15894cef7)
My questions are:
