LMS Data x750 PSUmake and model of the psu?
try taking the gtx 960 and use the igpu ?
http://www.lmsdata.com/pages/products/Power Supply/X750.htmlPlease post your PSU make and model.
Follow all of these steps thoroughly first - without skipping steps PERFORM THESE STEPS before posting about POST/boot/no video problems!
Then feedback.
Are you definitely sure it's the PSUWell i read some reviews on your power supply, some people said that it blew up and took everything else in the rig with it and costed them a ton of money, some said its working fine.
Well it is not a well know brand that is the problem.
A evga supernova g2 650W should be more than enough and it is a top tier power supply.
These were the only 5 reviews i found on that power supply, please change it ASAP.
Any recommendations for a low priced good PSUonly 100% sure it to replace all
What about EVGAWell they always talk about the new cxm/cx series from corsair the 2018 version, never go with the old version is pure crap.
Not really in my budget I'm looking for a good psu £30 to £48Well as i said, evga supernova g2 650W is amazing and top tier, but its 80$ on amazon highly recommended.
Just figured something out. When I put on the protective metal CPU case, and shut it tight with the lever, the pc will turn power on for 1 second then instantly turn off. However with the protective cpu case off, the pc will turn on and be stationary fans running, no beep or bootSee there is no such thing as a good power supply in that range of money.
The closeest one you go go for is the CX series 2018 from corsair.
else you can't really do anything else.
Be more specific, does what have contactdoes it have any contact with solder point , ground or that kinda stuff
My PC doesn't even start, when I power it on, it turns off after a second. I was taking off the fans to clean them, but now I'm getting this problem. All fans are plugged into the header.For what reason were you unplugging the wires for? And that psu doesnt look like a very good quality unit (don't hold me to that) but are all fans plugged into header? Is there anything in the bios about fan speed? Maybe you have it set to a certain PWM state where they only come on at a certain temperature
Wow... Good luck getting help nowIs there anyone useful on this forum
