Hey everyone!
I posted this on Reddit, too, but I figured I'd share it here too to increase my chance of getting to the bottom of this problem! Sorry, but this is going to be a long post! My rig:
This was built on October last year, although I got the 2080 on January 2021, but it has been working fine ever since.
Here's the issue: my PC randomly rebooted (as if I pressed the physical reboot button) while I wasn't around, I just turned it on and I had a single chrome tab opened. The PC didn't POST, it got stuck with the DRAM LED on. This happened once already, all it took was turning off and on the PSU but this time it didn't work. Not only that, sometimes after rebooting the PC it gets stuck on either DRAM, CPU or VGA, although only rarely on CPU.
So, I tried the usual troubleshooting with the old motherboard:
On this matter, when I tried one stick on B2 slot (which should have priority among the four) the PC started boot looping, i.e. getting all the way to VGA LED and immediately going back to DRAM as if I pressed the physical reboot button, then repeating indefinitely. Any stick on B2 slot had this effect, while any stick on A2 (the other priority slot) just made the PC stuck on any POST step as described before.
I thought that this could have been a motherboard traces issue, so I bought a new board (X570-F Strix) and rebuilt my PC, only to encounter the same issue. The thing is, this time it's A2 that is causing the boot loop, and not only that, this time I tried a single stick of RAM in any slot and it looks like A1 is doing the same as A2 while B1 and B2 are "fine" (still no POST, but it's better than boot looping I guess). I can't figure out the schematics, but as far as I know RAM slots are connected 2 by 2 to the CPU, so could this mean that I have a faulty CPU? I just hope that whatever started the issue didn't propagate it to the other components, or this will be impossible to solve. I'll try a different stick of RAM that I'll be borrowing from a friend of mine just to make sure it's not that, I'll keep you posted.
Thank you in advance!
- CPU: AMD Ryzen 3700x (stock cooler, Amazon warehouse)
- MOBO: Asus B550 Tuf Gaming (now Asus X570-F Strix)
- GPU: Gigabyte RTX 2080 windforce (used, 2 years old)
- PSU: Corsair TX650M (Amazon warehouse)
- RAM: Crucial Ballistix 2x16 GB 3600MHz RGB
- SSD: NVMe M.2 Sabrent Rocket 500 GB (PCIe 3.0)
- HDD: Maxtor 2 TB portable hard drive (opened and connected as internal)
- CASE: Corsair 275R
- Resetting CMOS
- Reseating CMOS battery
- Flashing BIOS update through EzFlash Utility
- Reseating CPU
- Changing GPU (I had an old R7770 by XFX laying around)
- Unplugging HDD
- Reseating RAM
