Hello everyone i would like to share a certain problem that's been annoying me for the past months or so with my PC. I am sorry for the long post.
Specifications:
Windows 8.1 Pro 64-bit
Intel Core I5-4440 3.1 GHz Turbo 3.3 GHz
AMD Radeon R7 240 4 GB GDDR3 Sapphire
Two 2 x 4 GB GR1600D364L11 memory modules
Delux 400w PSU / +12V1 - 17A / +12V2 - 14A / +5V 15A / +3.3V 24A / +5VSB 2.5A /
Asrock H87M (bios was originaly version 1.40 but i flashed it to 2.40)
Kingston SV300 120GB - No smart errors
Western Digital 2 TB Green - WD20EZRX - No smart errors
And two fans - intake and exhaust
So sometimes when i try to turn off the machine the fans keep running.When pressing shutdown in Windows it says shutting down then the screen goes black and it hangs like that. I left the pc like that for an hour to see if it's not some sort of feature of the motherboard. The problem happens sometimes randomly and is starting to get really annoying for me. To fully shutdown i have to either press the on/off switch on the PSU or press the start button on the case for 1 second. This is unusual since for other users with the same kind of problem it takes 4-5 seconds but for me it shuts down instantly. Last week it happened twice in a row after i cleaned up my pc. To try and resolve this i have tried the following without success:
Uncheck fast startup under power options
Disable S states
Running Memtest86 no errors found (2 passes)
Stock UEFI setup
Update UEFI
Switch memory places
Drain power and remove CMOS battery
Update to latest drivers
So what do you guys think? I think it's either the motherboard or PSU but a solution would be nice from you all.
Specifications:
Disable S states
Stock UEFI setup
Update UEFI
