• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
Question PC Fans turn on for a few seconds and then turn off.
Jul 15, 2020
13
My older PC Build won't stay on for long periods of time. The fans ( CPU and PSU) will turn on for a few seconds and then turn off, leaving my computer unable to start. I've tried swapping RAM slots as well as everything on this list: https://forums.tomshardware.com/threads/no-post-system-wont-boot-and-no-video-output-troubleshooting-checklist.1285536/. Perhaps I've missed something but I recall checking at least 20 of the checklist points. It would be appreciated if anyone greatly knowledgeable with computer systems could Please help.
System Specs:
PartModelMakeAge
PSUATX-PR800WApexia(1 year~? Unsure, Given as a gift.)
CPUAthlon X4 860KAMD3~ years.
GPURadeon R7 260X WindforceGigabyte4~ years.
Update: The PSU was tested and was confirmed to still function. (Paper Clip tested.) The motherboard was swapped with another model that supports the same socket and the problem is the same. The CPUs were swapped (same model) with each motherboard, yielding the same problem.
13
(More Updated)
Hello all, I have a somewhat old PC build comprised of used & gifted parts that doesn't seem to want to work anymore. It was working fine up until a few days ago before it refused to turn on at all. The PSU is in working order as it is new and tested (using a paper clip), the motherboards (different models same socket support) have been swapped along with the CPUs (same model) but the results still stay the same; the fans(GPU, CPU, and PSU) stay on for a moment before turning off without posting. I have also tried all, if not 20~ of the points on this checklist https://forums.tomshardware.com/threads/no-post-system-wont-boot-and-no-video-output-troubleshooting-checklist.1285536/). It's honestly been quite a pain in the rear for me, I'm hoping someone more tech savvy is able to help. Thank you!
Here are my part specs along with the make, model and relative ages.
PartModelManufacturer Age
GPUGV-R726XWF2-2GD (rev. 2.0)
GIGABYTE1-2 Years.
CPUAMD Athlon™ 860K
AMD3 Years.
PSUATX-PR800E (800W)Apevia1-2 Years.
MotherboardMSI A88xm GamingMSI3-4 Years.
hang-the-9
Paper clip test is not really a good test past making sure the PSU has power, it won't tell you if it's able to work properly to power you system.
Two most likely things is the power supply then the motherboard. That power supply is a low quality one.
Jul 15, 2020
13
What would be a good way to test the PSU? And how would the motherboards be at fault, I've tested two different ones and both seem to get the same result?
