[SOLVED] PC freezes after power outage. Don't know how to follow through!
TechnicianX
Commendable
Sep 9, 2021
I had a power outage that lasted a split second and I can't figure out why my PC freezes after I log in. Occasionally, I'll get a BSOD with WHEA_UNCORRECTABLE_ERROR and CLOCK_WATCHDOG_TIMEOUT, but most of the time I'll get a cursor loading circle and it'll freeze on the Desktop right after logging in.
  • Went into safe mode, everything's working fine.
  • Ran a bunch of sfc and dism scans. Everything's normal.
  • Did a system restore 3 times, worked on the 3rd time after selecting the oldest restore point. However, after shutting off, Windows will freeze again.
I have no idea what to do after this. I'm suspecting it's more of a software issue than hardware, but I'm open to any opinions at this point.
dump file
Specs:
CPU: i7-4770K running stock.
MB: ASUS Z-87 Deluxe
Video: Asus GeForce GTX 780 Direct CU II
RAM: 16 GB
PSU: Corsair TX850M
HDD: Western Digital 2TB, Samsung SSD 850 Evo (SSD is the main disk)
OS: Windows 10 Home 20H2
Was PC on during outage? power surges can damage hardware. Even if it was off, was it plugged in? WIn 10 isn't off by default when shut off, its in a hybrid hibernation. Great for startup, not so good for power surges.
Both of those errors are hardware errors. Both relate to CPU, might not mean it is CPU but we start there.
since it freezes in windows we will have to test CPU outside windows
DOwnload and make this on another PC: Prime 95 bootable - https://www.infopackets.com/news/10113/how-fix-bootable-prime95-stress-test-hardware
Prime 95 how to Guide: http://www.playtool.com/pages/prime95/prime95.html
safe mode working just means it isn't putting as much stress on hardware as normal mode.
They are very odd errors to...
They are very odd errors to get if it was just a software error. If it was say windows that didn't work I would expect other BSOD than those 2. Its why I leaned towards checking hardware over software.
I have asked a friend to look at dumps, WHEA errors almost always show same results but the other one might show something.
Hi, I ran the dump files through the debugger and got the following information: https://jsfiddle.net/90qrneof/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:MEMORY.DMP (Jan 4 2021 - 17:17:56)
Bugcheck:DRIVER_POWER_STATE_FAILURE (9F)
Probably caused by:memory_corruption (Process: System)
Uptime:1 Day(s), 17 Hour(s), 00 Min(s), and 46 Sec(s)
Possible Motherboard page: https://www.asus.com/SupportOnly/Z87DELUXE/HelpDesk_Download/
There is a BIOS update available for your system. Wait for additional information before deciding to update or not. Important: Verify that I have linked to the correct motherboard. Updating your BIOS can be risky. Never try it when you might lose power (lightning storms, recent power outages, etc).
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
