Hello people, I got my PC for over a year now and never had this problem. 2 days ago it started and the random crashes occured. The PC just freezes, nothing reacts anymore (no CTRL + ALT + DEL or anything). If you played any music, that stops aswell. The current picture stays on the monitor and you can just shutdown the hard way.
The freezes occur from anywhere between a few minutes to 1 hour or in rare cases a little longer.
My PC configuration:
Operating System Windows 2000 SP4 and all patches
AMD Athlon FX-57
Motherboard: Asus A8N32-SLI Deluxe
2x 512 MB Corsair PC3200 DDR Ram
ATI Radeon 1900 XTX 512 Ram
Power Supply: Levicom 450W
I didnt change anything on the hardware for a long time.
What I tried already:
- It isn't the OS, because the PC can freeze in the BIOS and when using a memory diagnosis bootdisk in DOS aswell.
- I cleaned the PC of all dust and checked CPU temperature. It starts at 37° and goes up to 45° and stays constant there. Note that in 1 year of using the PC I never had any problems with overheating, even when I had it turned on for 2 days on a hot day.
- Removed my 2 Ram blocks and replaced it with a new Ram block (fresh from the shop). Also tried the new one in all ram slots. Didnt help, same freezes again.
- Replaced my graphics card with a graphic card from a friend to check if it was the graphic card thats causing the problems. Didnt help again.
So I would be very grateful if anyone can give me a hint where to go from now. Is it the motherboard? The CPU? Or what should I try next? Thanks for your help, it's greatly appreciated!
AMD Athlon FX-57
