OK HERES ANOTHER PC I AM BUILDING. I WANT TO BUY IT RIGHT NOW SO ANY HELP ASAP WOULD BE GREATFUL THANK YOU
LOGISYS Computer CS206BK Black Steel ATX Mid Tower Computer SOHO Case 480W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811148044
ASRock M3A770DE AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
Mushkin Enhanced Silverline 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Triple Channel Kit Desktop Memory Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226040
HIS H467QR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161315
AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
IS THIS A GOOD SETUP AND IS EVERYTHING GO WITH EACH OTHER? I WANT TO GO AS CHEAP AS POSSIBLE.
