Question PC is running slower all of a sudden ?
Jan 6, 2025
5
Hi,
As the title says, my pc is running slower since a couple of days, be it opening a firefox tab, file manager or unzipping files.
It's a new pc I build a month ago with the following spec:
MBD: Gigabyte Z790 AORUS ELITE AX
CPU: i9-14900KF
GPU: Nvidia RTX 4070-S
SSD: WD Black SN850X M.2 2TB
RAM: Crucial 16GB x 4
OS: Win 10 Pro 64-bit
Since I'm a layman, I don't really know what the problem could be. Reboots didn't help, task manager doesn't show any excessive usage of cpu, gpu or ram, and a virus scan says the system is clean. I also didn't install any software before that and my drivers/os are up-to-date.
I'd be gratefull for any help or suggestion!
You haven't mentioned any detailed figures about CPU speeds, XMP settings, etc and I presume you haven't run any benchmark or stress programs.
Similarly, we've no idea what your CPU cooling solution is (air or water). If the cooler is malfunctioning, the CPU might get hot and start to throttle.
There's no mention of your PSU - a critical component. Is it new or old, high quality or junk?
If the problem is Windows based, you might have picked up a virus (unlikely).
Easiest way to see if Windows is at fault is to perform a fresh Windows install on a cheap SATA or M.2 drive with your current Windows drive (and any other drives) unplugged.
Reactions: clearasarock
Thanks for your reply and pointing out what I didn't mention.
Task manager is giving me a CPU speed of 0,79GHz at 1% usage though the base speed is said to be 3,2GHz.
XMP setting are DDR5-6000 36-38-38-80-1,350.
The CPU is air cooled with a Noctua NH-D15 G2, the MB shows a temp of 27°C.
The PSU is also new, its a Seasonic GX-850.
I ran a Userbenchmark with following results: UserBenchmark, and if I interpret the results correctly, does my CPU have a problem?
The CPU is severely throttling! What are your CPU temps? What cooler do you have?
I have a Noctua NH-D15 G2, and the CPU temps I have are from the MB sensors, showing me 25°C for the CPU, which I can more or less confirm by touching the heat pipes of the cooler and the backside of the MB.
From what I could glance on the web during work, it seems to be a known problem for Intel CPUs to be throttled at 0,8GHz. I just came home so I will look into it tomorrow.
what are you using to measure the temperature ( bios doesnt count)
you can also remove the cmos battery and replace it with a new 2032 battery. and see if the battery has gone in the motherboard and it will also reset your settings.
that cpu personally should be under a aio otherwise it needs voltage locked down.
make sure bios is updated to latest as these cpus have a defect. that was addressed in a bios patch due to to much voltage being applied. and potentially contaminated cpus causing premature failure.
For the temperature I'm using the MB software Gigabyte control center. I don't know how accurate it is and if you would recommend something else, but through the touch those values seems ok.
I updated the BIOS early on, as I read about the voltage issues those CPUs had as well about the corroding problems, but didn't intel recalled those affected?
I'll try replacing the cmos battery and tell you if it helped. As for the voltage, what min/max voltage would you recommend?
Replacing the cmos battery did the trick! The CPU is running like it did UserBenchmark 2
Thank you everybody for your help! I'm glad the solution was that easy to implement.
If you have any other advices as how to increase stability, I'd be glad to hear them.
And again, thanks a lot!
Hw monitor is better for temps
https://www.cpuid.com/softwares/hwmonitor.html
Also it's hard to recall chips that are effected because it's not something visible to naked eye. It's pot luck. It's why I don't recomend intel CPUs anymore of lga 1700 cause it could be old stock.
That being said best way to prevent damage is to try to keep performance but wind down voltage in other words under volt. There should be a option to load Intel's own optimised settings. Which is a override of the normal board settings.
View: https://youtu.be/B3EW5lRIZYc?feature=shared
The video below is just a guide it's best you have a look around and get a idea on how intel undervolting works as it's a bit more complicated then it used to be. But undervolting doesn't damage the cpu if anything it keeps the cpu alive longer you may lose a minor few couple of gigahertz but you'll get a more stable all core boost and less likely to overheat.
View: https://youtu.be/aB81bgzNM1w?feature=shared
For example I use amd my pc would overheat with 5900x with the voltage being constantly slammed to it's max of 1.5v all the time I turned it down to 1.3 all cores are locked at 4.7 stable. But temps never go past 82c under the 90c limit.
Voltage unsure what new voltage would be but 1.35v should be safe preferably lower.
I'm sure more people who have intel boards will know more then i.
I would open hw monitor..
Write down min and max temp CPU and GPU.
Keep app open.
Then open game play 30 minutes close game.
Record your max temp. CPU and GPU.
Compare see if there are any glaring issues.
Mostly highlighted in red.
