[SOLVED] PC keeps booting then shutting down. Need Help!
Alberto12
12
I hadn't used my pc in maybe 3 months, then when I tried to start it up today the pc would turn on (fans and lights running) but within around 10 seconds it would shut down and restart. This process continues infinitely. My tv wont pick up a signal in time to see the bios or startup. I have tried removing the power button pins and using a screw driver to touch the pins but the problem continues. I am not the best with computers. What should I do?
I have just noticed that the back of the power supply is open. The coils and everything is visible. Is this normal? could dust have gotten into the power supply and is cutting power to the pc?
