Question PC locked up when attempting to use HWiNFO64 to monitor temps ?
bikemanI7
230
17
10,595
Hello All
I wanted to use HWiNFO64 to monitor system temps a bit this morning while was doing a Defender scan.
The only problem is the PC locked up totally, couldn't even get Task Manager open to end task, ended up using physical reset button on Tower
The BIOS on this iBuyPower prebuilt is February 2024 version, i haven't updated it as yet, debating if I should or not at this point as I'm being very cautious with the newer system thus far, plus i don't know too much on AMD side of things as yet--learning as much as i can though
it never locks up with any other programs though, so maybe it's a bug with HWiNFO64, i'm not really sure.
Hello All
Hey there,
To me, this sounds like a software issue, rather than a bios issue. However, being an AMD system owner, you should get used to bios updates, and not be fearful of them. It's akin to updating a driver nowadays. It's made pretty easy to do.
So, just to be clear, HWinfo crashes the system with the scan only, or other times like playing games too? If it's only the former, then don't run the scan while monitoring.
Are all system drivers up to date? Chipset is important.
Yes I select sensors only when opening. HWINFO64 opens for a split second, monitor goes black, and then to restart system only choose is reset button on case.
Gonna get used to the bios updates slowly, still learning on AMD systems though.
Otherwise everything else I ran runs fine as can be.
Like games, Nero burning rom, like Nero video, all my steam games, ea app games
Chipset Drivers are up to date
Left Off PBO Optimizer for now, originally had that activated as followed another forum to optimize AMD Ryzen 7 7700X for performance and cooling, that maybe where i screwed up already lol.
Bios update was successful
Ohhh i didn't know about Ryzen Master, but now i do, will get that shortly here, here i was thinking like my older Intel systems
After successful bios update, only did the following
Made Sure Re-Sizebar was enabled and Above 4G Decoding
Expo set for Profile 1 like before, so my 5600mhz DDR5 RGB Ram runs as it was before lol
Left off this time PBO Optimizer as last time i turned it on following advice for comment section of a youtube video how to optimize a 7700X for balance of Power & Temps lol, might've been where i screwed up (as i wanted to keep CPU Temp under 85C with Tower Air Cooler)
((tad nervous on reopening Hardware Info 64 though if i wish to troubleshoot this issue further, guess i'm gonna have to soon and turn Debug mode on and get the report if it crashes again))
Reopened after the bios update and making sure the settings in bios was properly set as before
Now PC hasn't crashed, Hardware Info 64 open in the background and so far working fine it appears.
Fixed with the bios update? not entirely sure what the exact fix was lol, but its working, so im happy
A Windows Defender scan will definitely drive your computer to its maximum temperature levels. That may be the cause of your locking up. You can try to get ahead of it by manually setting all of your fans to their maximum level before starting the Defender scan.
Oh ok, well even without Defender scan running, previously Hardware Info 64 was freezing as soon as opened it, well more than freezing--Hard locking the system (black screen) and was forced to use PC reset button.
Since bios update this morning, and readjustment of some settings
Have it running now, and appears to be working fine thus far---not entirely sure what fixed it, but i'll take it
As i typically like to do Defender and then Malwarebytes custom scan prior to doing my system backups each month, i don't bother with weekly scans anymore like i used to
Other files backed up to other external before monthly main backup if need be, or Onedrive if nothing critical file wise
Spoke too Soon!--Ok not running Hardware Info 64 anymore lol...that time it suddenly black screened and auto restarted. Cause unknown--But i do have the Debug log now! so adds that to Hardware info forum post
Hope to in early August purchase 2nd M.2 NVMe to be Game NVMe, and do a clean install of Windows 11 Pro, and hopefully all stable after that lol. It usually is at least other days previously was perfectly stable for hours as long as i wasn't running HWinfo64
Well now it's crashing while doing other stuff
these are the settings i adjusted to keep temps at around 85C
Precision Boost Overdrive to Advanced
Then Curve Optimizer All Cores, Negative 30
Checked to make sure Re-sizeable bar was on
and Expo was set to proper Ram setting like it was when i took pictures with my Cell phone prior to doing the bios update
Previously it only crashed if i ran HWInfo64, now its doing it with other programs, but no real blue screen at all--so i don't have what its crashing on, no memory dumps either, except its set for Automatic Memory Dump in system recovery settings
Im so confused--so disappointed thus far, this gonna cost me alot of money to ship back to Ibuypower if i can't solve this crashing on my own, as the case is very heavy to the point i can barely lift it myself
Guess i should've replaced Gaming Laptop after all like i was gonna in the first place
Gonna run a memory test over night, and see if that finds anything,, and do my best to sleep
**Spec sheet for Order shows 5600mhz ram, yet i put in my signature 5200mhz, maybe i mistyped not sure**
