Question PC makes bass noise when booting up
Jan 16, 2024
Does anyone know what could be the reason, strange bass sounds appear during loading? Same thing with headphones. Always in the same sequence.
This didn’t happen before, but recently I reinstalled the audio drivers and some of them apparently caused this, but I'm not sure. I installed older versions, but nothing helps.
Motherboard: MSI Tomahawk Z790 WIFI
View: https://www.youtube.com/watch?v=UQNONEJsYz8
You might want to see what BIOS version you're on. As for your OS, did you migrate it from another platform? If you're reinstalling your audio drivers, make sure you've installed them in an elevated command, i.e, Right click installer>Run as Administrator.
