Hi everyone,
I've run into a bit of a strange issue here. I recently put together a new PC with the following parts:
Ryzen 5 5600X with Noctua NH-L12s
MSI MPG B550I Gaming Edge WiFi
MSI RTX 3080 Ventus 3X OC LHR
Klevv Bolt X 32 GB (2x 16 GB) 3200 Mhz CL16
Antec High Current Gamer 850W Gold (2021 Model)
Seagate Barracuda 510 1 TB + WD Blue SN550 1 TB
I first built this PC with an EVGA SuperNOVA GA 750W power supply, but had constant crashing issues when gaming or even browsing the web, so I decided to switch it out to the Antec, which is a Tier A PSU on https://linustechtips.com/topic/1116640-psu-tier-list/
This generally fixed the issue but the one scenario where I still get regular crashes/instability is when I restart the PC, or shutdown and power on soon after. The PC either reboots at the motherboard splash screen (Windows spinning animation), or it makes it to the lock screen and is quite unstable and reboots a short while later.
I found the solution for this to be to switch off the power supply and press the power button, thereby draining excess charge in the capacitors. Once this is done, the PC boots up normally and everything works without a hitch. Similarly, if I let the PC sit for 15+ minutes, it will boot up normally as well - further supporting the theory of a charge drain issue.
Does anyone have any recommended solutions? I'm not sure if I will be successful in returning my components as defective as the issue seems to be oddly specific.
Any help would be appreciated.
