Question Pc not working after bios setting/cmos reset
Dec 6, 2023
I messed something up in my bios, and tried resetting the cmos battery but that did not work. Left it out for like 5-6 minutes. The only thing i changed was my ram speed, from “auto” to 3600mhz. Now when i try to boot up my pc nothing happens. All the lights in my pc turn on and the fans spin, but my keyboard, mouse and microphone don’t light up and i’m not getting any display.
Specs:
AMD Ryzen 5 5600
RTX 3060 ti 8gb
ASUS Prime a-320m-k
32gb ddr4 RAM (kingston fury i think)
Samsung 980 pro 1tb ssd
Toshiba hdwd 110 1tb hdd
If you want to clear the CMOS, you disconnect from the wall and display, then remove the CMOS battery from the motherboard, for at least 30 mins. Press and hold down the power button to drain any residual power. Replace the battery and then see if you can get into BIOS.
Your motherboard has a feature known as Crash Free BIOS 3 ;
View: https://www.youtube.com/watch?v=xb6FbJwVg8Y
This video should guide you through it.
You should try and pass on an image of the sticks of ram's stickers for us to se what you have to work with.
You forgot to mention the make and model of your PSU and it's age.
Specs:
AMD Ryzen 5 5600
RTX 3060 ti 8gb
ASUS Prime a-320m-k
Hi, if this issue is fixed please mark it “solved”. If not, check this out.
View: https://m.youtube.com/watch?si=NBsc-BycmPc36gR-&embeds_referring_euri=https%3A%2F%2Fwww.google.com%2F&source_ve_path=MjgyNDAsMjgyNDAsMTY0OTksMjg2NjQsMTY0NTA2&feature=emb_share&v=AdREnj2m208
