[SOLVED] PC or Game problem? (Elden Ring)
vilok9
11
Hi all,
I will try to summarize, I bought Elden Ring because I read the PC requirements and I should be able to play it in Maximum with no problem at all, but when I try it, the game keeps having a lot of FPS drop (usually from 60 to 40 FPS, but even 15 FPS sometimes). I read that that this game has a lot of performance problems in PC but still I think that my computer should be able to run it.
I play on 1440p resolution, but tried to lower it to 1080p and the problem still persist.
This is my sistem information from DirectX Diagnosis:
The GPU is a Radeon 6900 xt
System Information
Time of this report: 2/25/2022, 13:44:29
Machine name: DESKTOP-416VR86
Machine Id: {545E0E37-7085-4DFE-BCE0-92707099A34F}
Operating System: Windows 11 Pro 64-bit (10.0, Build 22000) (22000.co_release.210604-1628)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: Micro-Star International Co., Ltd.
System Model: MS-7C91
BIOS: 1.80 (type: UEFI)
Processor: AMD Ryzen 7 5800X 8-Core Processor (16 CPUs), ~3.8GHz
Memory: 16384MB RAM
Available OS Memory: 16310MB RAM
Page File: 13239MB used, 14334MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.2.2
DxDiag Version: 10.00.22000.0001 64bit Unicode
Could you guys give me a solution? I posted another thread a month ago about the performance of my PC, which I kinda solved (I am able to play Forza Horizon 5 in maximun quality), so I really don't know what is happening right now...
Btw, sorry for my english, not my mother language.
Hey guys, thanks for all your answers, I was tryng to monitor all the specs during gaming and I saw something unusual. It is from the GPU: the memory clock seems to work fine (2000 Mhz more or less), but the core clock doesn't go above 1000 Mhz, and it is supposed to work at 2494 Mhz. I guess it can't be working always at that speed of course, but not even 1500 Mhz while playing? The temperature usually is not higher than 55ºC, so maybe this could be causing some issues in performance?
Thanks in advance
Okey guys, after a lot of checkings, I tried to force my GPU's core clock to run on minimum 2000 Mhz (with the AMD Radeon Software), and it seems to improve the performance by a lot. Still minor sluttering but this seems to be...
brand and model of the psu?
how full is the ssd?
the ssd has like 30% capacity free, should I try to free it more? I could do it with no problem
The psu is a Nfortec Sagitta RGB 850W 80 Plus Gold Full Modular, I considered to change to 1000W but as I was able to run most games I didnt pay more attention to it.
Well, now the ssd is 75% capacity free haha, just deleated all the games that I don't play anymore, let's see if it improves the performance
I bought Elden Ring last night and had some unrelated issues. I went to the Steam discussion page and there are already hundreds of posts with issues. I saw many saying they couldn't get more than 10 FPS with hardware that exceeds the recommended specs. I couldn't even post a question on there because there were so many people posting. I don't think there's anything wrong with your PC.
Yes yes I saw it, probably just need to wait for a patch.
But still, sometimes I worry because this is my first PC completely assembled by myself, and when something doesn't work as it should workl I just panick
Read this thread.
Thanks in advance
Thanks in advance
Okey guys, after a lot of checkings, I tried to force my GPU's core clock to run on minimum 2000 Mhz (with the AMD Radeon Software), and it seems to improve the performance by a lot. Still minor sluttering but this seems to be more related to everyone not just my PC. For some reason, the AMD software had like 500 Mhz minimum and it never goes above it unless you force it. If someone is reading this looking for a solution, just remember to make profiles for each game, like I did for Elden Ring, not in global, there is no need to force the GPU with games that require less power.
