[SOLVED] Pc parts list
Jan 19, 2021
Hi, Im about to buy a gaming pc and I would like your opinion on my parts list, thank =)
Case- antec nx800
Mobo- asus tuf b550
Cpu- ryzen 7 5800x
Gpu- asus tuf 3070
Ram- hyperx fury rgb 3200 2×16
Nvme- samsung 970 evo 500gb
Hd- western digital blue 4t
Aio- nzxt kraken z63
Psu- coolermaster 850w 80+ gold
Monitor - odyssey g7 27'
Your build will work as is.
My thoughts:
Love the case. Plenty of airflow.
Mobo is ok, I have no preference.
5800X is as good as it gets for gaming.
Do you need 32gb? No harm in getting extra up front.
But, ryzen needs fast ram to get best performance.
Look for a 3600 speed kit in the mobo qvl list to insure compatibility.
You will pay extra for RGB. Not my thing.
Love the samsung quality.
With ssd prices down, try to go all ssd.
Defer on the HDD until you actually need space.
Look for a 1 or 2tb m.2 ssd.
If budget is an issue, intel makes a good 660p 0r 665p m.2 device.
Your case is an outstanding one for air cooling.
A cooler like a noctua NH-D15s will be cheaper,cool equally well, be quieter, more reliable. and will never wear out or leak.
What is the make/model of the psu?
coolermaster makes some ok units as well as some dogs.
850w is fine, it will only use the power demanded of it, regardless of the max capability.
Look for a top quality unit with at least a 7 or 10 year warranty.
Hi, thanks for the replies.
This is not a pre build, those are the parts I picked.
Im from israel so everything is expensive as f.. so i dont think i can upgrade to 1tb nvme because itll cost as much as a 4tb hdd just for the extra 500gb, but maybe.. i dont know.. still thinking about it.
I dont really think ill need the 32gb ram right now( I usually close the extra chrome tabs) so you think gling for 2x8 3600 will be better?
The psu is MPY-850V-AFBAG-EU with 10 years warranty or i can get corsair CP-9020196-EU with a 10 year warranty too for almost the same price
Thank again
Reactions: Mr.poopybutthole
