G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I have a Gateway Performance 800 with 800MHz P3 inside....'and a problem
maybe.
Every time I press the button on the base to turn the machine ON, the light
on the front comes on and it makes the usual sounds, but after 2 or 3
seconds, it switches itself OFF.
It just keeps doing this until I take the plug out at the back for app., 10
seconds and re-insert it.
Then it does the same routine as described all over again.
Can anyone help me with this?
Thanks.
Geo.
maybe.
Thanks.
Geo.
So I wouldn't say you are totally out of the woods
