pc problem possible motherboard broken.
darkfantoom
7
hi
This is my setup :
OS: windows ultimate 64-Bit
CPU: intel i7-870
Motherboard: Gigabyte GA-P55A-UD4
graphics card: Gigabyte GTX 580 Super Overclock (dual BIOS)
RAM: 4 x 2GB A-Data gaming series 1600Mhz
My pc is 3 years old and i have this problem for over a year now
this is my problem :
When my pc boots there is only 8183Mb of memory then if i check my BIOS it says total memory 8192Mb total and extended memory 8183Mb. Then i check my DIMM's in the bios and all of them are 2048Mb. after booting windows aprox. 10-20 minutes(sometimes it takes hours) later my pc freezes or gives a BSOD(page not found). I need to manualy reboot him and then there is only 4086Mb of memory available(after this he never freezes again). if the pc is powered off for a day it goes back to the 8183Mb of Ram and freezes again.also sometimes it happens that my BIOS of my GPU is corrupted then i need to switch the BIOS and switch back to repair it. i can also happen that when my pc is at 8Gb of ram he freezes inside the BIOS screen. Now i installed windows 8.1 on the pc and now he freezes when loading windows and when he's loading the recovery cd (so i cant access windows settings).
edit: when the pc freezes it doesnt matter if i'm working on it or not.
Things i tried for fixing it.
  • -Memtest of each DIMM separately and in tests in pairs (each test was running for 4-5 hours).
    -Flashed BIOS(motherboard) to latest version.
    -Let the ram run at 1333Mhz.
    -Checked the memory of my GPU.
so what could be the problem? is it possible that my motherboard or something else is broken ?
thanks for the help
greets
Most of the time when it is because of either motherboard or CPU it is the board so most likely we are looking at new motherboard.
well i was going to reply that my pc found a way to boot up windows 8.1 and that he was running for over 20 hours but just when i wanted to hit answer he gave a BSOD 😀 i took some pictures of the BIOS of the channels and it seems that the bios blocks out channel 3 and 4 when he drops the 4GB.
here are the pics
