Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
This is going to be long winded, so sorry for the lengthy read. I am having
some issues with my PC, first off I changed my drive from FAT32 to NTSF.
After the change, which I hadn't noticed for a while, my system restore
would not work.
In My Computer > Properties, there is no check in the "turn
off system restore". Under the Services tab in the Administrative Tools it
says that it is stopped, when I hit start it gives me an error stating
"Could not start System Restore Service service on local computer" "Error
1359: An internal error occurred" That is the first issue.
The next issue is that I downloaded some software that I probably shouldn't
have, I ran into some problems with it so I uninstalled it and ran all of my
stuff( Spybot, AVG, Bazooka, AdAware) to see if it left some stuff behind
(Bazooka detected B3D Projector and Winpup) which I tried to get rid of by
using the procedure they suggested but what I was supposed to delete was not
in the registry.
When I try to run Nero, the PC reboots. I have absolutely no clue. I
uninstalled and reinstalled Nero but to no avail. There is another program I
have called TuneUp Utilities. I can run all of the options, but when I try
and use the "TuneUp System Optimizer" option the system also reboots.
I'm not sure what the connection is, but it is odd. I either don't have or
can't
find my XP disc, the computer came preloaded so I'm not sure if I even got
one, so I can't backup everything and start form scratch. Does anybody have
any suggestions? Thanks for your time.
would not work.
in the registry.
can't
