[SOLVED] PC randomly buzzing and freezing for less than a second
May 1, 2020
Hello, I'm running w10 x64 on an MSI 470 gaming pro , gskill trident z 3200, MSI rx 570 armor oc. I clean install w10. Check registry, SSD , HDD, I changed my PSU to thermaltake toughpower Grand 750, I changed the sound drivers, and the device manager uninstall all the software display and sound. I changed the bios to an older versions same for AMD software adrenaline and older ones. I uninstall all the hardware couple of times. The freezing and buzzing thing happens every couple of hours and lasts around 0.3 sec, after that is like nothing happened. I don't know what to do
I had a similar issue with the buzzing and a quick stutter when it happened, I went into the sound settings and lowered the frequency down slightly and it fixed it completely for me.
