The other day I upgraded some parts to my computer and after everything was placed and I installed the new GPU drivers, it seemed fine, until randomly crashing while playing a game. The new parts were a Gigabyte GeForce RTX 4070TI Windforce, a Corsair RM850x 80+ GOLD, Samsung 2TB 970 EVO Plus NVMe M.2, and a fractal pop xl silent case. Specifically, what happens is that randomly, (not even when playing a game necessarily), the display freezes, sometimes the application crashes a second before this freeze, but it varies wildly, all input and output is frozen as well, but the display is still on and showing the last thing open as it crashed. Rarely, it will shut itself off after this freeze, I have to turn it off manually. On only one crash has there been a blue screen; in that case there was an error code: DRIVER_IRQL_NOT_LESS_OR_EQUAL (after a quick lookup, I think this means something is wrong with some driver or memory). The crash happens when the GPU is in either PCIe x16 slot, regardless of whether or not the new SSD is in the second m.2 slot, and regardless of how much of my 4x4GB ram is slotted. After such a crash, the computer usually does not POST (no diagnostic LED [other than a line of orange, which is usually always on] or sounds) and sometimes requires reseating all RAM sticks, the GPU, and removing all USB connections, sometimes requires less. Even then it may not happen, and I may need to wait a few minutes before it will POST again; high variance with time after a crash before I can get it up and running. If there is no crash, when I reboot, everything starts up fine. If I do need to reseat everything, it seems that at least video drivers have something wrong because the windows login screen is in a lower resolution than my monitor (360p I think?) before automatically changing to the full resolution several seconds later. I have flashed the BIOS and installed the latest GPU drivers twice, once as a clean install (both result in crashes). All voltages seem to be fine (within .1 or less) in the BIOS. I have not run MemTest (86 or 64), since RAM was never an issue before the upgrades yesterday and it all shows up in BIOS and Windows (it's already 1AM, but I will start memtest after leaving for work tomorrow morning). I have not tried my old GPU (EVGA GeForce GTX 970), or old PSU (EVGA 500W 80Plus [although I don't think this would be of use because of the GPU power draw]). I have not tried reinstalling Windows (but would do on the new 2TB NVMe) or checked for Windows updates. I was able to get a really poor-quality photo of HWMoniter (v1.51) and planned what it would display as it crashed (because I wouldn't be able to expand or collapse anything else).
SPECS:
SPECS:
- MOBO: GIGABYTE H370M D3H GSM
- CPU: Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
- RAM: 4x4GB 2400MHz DDR4 (2 pairs of 2 mismatched brands, same speeds)
- GPU (new): Gigabyte GeForce RTX 4070TI Windforce
- Driver Version: 536.23
- PSU: (Corsair RM850x 80+ GOLD)
- Various Drives (see below screenshot)
- OS: Windows 10 Home
- Build: 19045.3086
