So I have a Lian Li Lancool 215 case, a Gigabyte Aorus x570 eilte mobo. the pc is built and runs perfect. however, if i unplug my monitors, peripherals etc... only leaving the psu plugged in and start my pc ALL fans work and run, then i plug in my peripherals and monitors and turn on the rear case fan does not spin at all, occasionally it will spin for half a second when i first switch the pc on, but it stops almost immediately. in the case the fans are attached to a panel that controls the LEDs etc, and ive swapped fans around to test if its the fan or the 4 pin connecter but all the other fans work in the connecters that the rear one was plugged in to. its fine for now but im worried that when i full load my pc or it gets stressed things will get too hot too fast and obviously that can cause many serious issues. any help or suggestions would be appreciated. the Sys Fan plug on my mobo is a 4 pin, the rear fan in question is a 3 pin, can i still put it in there to test ? and then manage it via bios? thanks in advance (i dont post on here often so i think ive posted this in the correct area)
