Hi everyone, I had previously posted about a similar issue but I didn't want to revive a dead post which at the time I thought I had resolved. Apologies in advance, this is going to be a long and messy post, please do let me know if anything needs clarifying!
The problem
I have been using my build (specs below) for quite some time now with no issues, however, recently I started doing some editing in Premiere Pro and my PC started to reboot whenever I was rendering or playing back rendered video. This reminded me of my previous issue where I could not run Cinebench multi-core tests - as soon as I hit start, the PC would reboot. No BSOD or error messages. I previously resolved the Cinebench issue by updating my chipset drivers. When I had the issue with Premiere Pro the other day, I decided to try Cinebench again, and lo and behold, the same issue is back. I also started to notice this issue in Spider-Man Remastered. I cannot not play the game because of it. As soon as I get past the first cut-scene of the game, bam, reboot with no BSOD.
I have checked Event Viewer on each occasion, and all I can find is a critical Kernel-Power event ID 41 task category (63).
All other games and high and low load activities except the above, I never have this issue. I was running a curve optimizer with negative 5 on all cores, +100MHz CPU boost override and PBO limits on Auto when I first encountered the issue. So I figured the problem may be these settings, so resetting BIOS to defaults was one of my first go-to's. I also kept a check on temps and everything seems within "normal" ranges for Zen 3 as far as I can tell. Usually ranging from 50C to 80C under max load, depending on whether I have custom BIOS settings or not of course. Including my specs, what I've tried so far and some findings/things to consider below:
Specs
Mobo: MSI B450M Mortar
CPU: Ryzen 9 5900x
CPU Cooler: NZXT Kraken X62 AIO Water Cooling Unit - 280mm rad (behind the rad in pull config)
GPU: MSI RTX 3090 Ventus 3X 24GB GDDR6X
RAM: Kingston Fury Renegade DDR4 3600MHz CL16 32GB Kit (2x16GB) - XMP Profile 1
PSU: Corsair RM 850 W 80+ Gold Fully Modular ATX PSU initially (note - I have now upgraded to Corsair RM1000x as I was convinced my issue was with my PSU, but that did not resolve the issue)
Storage: WD S3750 1TB NVMe SSD with Heatsink
Case: NZXT H400i mATX
What I've Tried So Far
I will outline further below the scenarios in which I was able to run Cinebench either fully or for a few minutes, but first, a list of all of the different things I have tried.
What seemed to help (but not resolve) the issue
The problem
Specs
CPU: Ryzen 9 5900x
- Checking Event Viewer for clues (critical Kernel-Power event ID 41, TC 63)
- Removing undervolt/OCs, resetting BIOS settings to default
- Downloading the Cinebench app from the Microsoft Store as opposed to from the Maxon site
- Closing all other apps when running Cinebench, Premiere Pro etc.
- Disabling antivirus etc.
- Trying to watch for signals using HWInfo - what happens just before the PC reboots? [I can't see anything unusual - too fast!]
- Adjusting fan curves in NZXT CAM
- Updating BIOS to the latest version
- Uninstalling old chipset drivers and installing new chipset drivers
- Testing RAM for errors with memtest86 - no errors found on 2 passes
- Disabling memory fast boot
- Disabling fast startup in Windows
- Changing PSU from RM850 to RM1000x (most of my tests were run on the new RM1000x)
- Testing with PBO on Auto, PBO disabled etc.
- Testing with custom PBO limits such as 142 PPT, 90 TDC, 140 EDC / 185 PPT, 125 TDC, 170 EDC
- Disabling Global C-State Control
- Testing settings like Power Supply Idle Control on auto, low and typical current
- Trying to lower SoC voltage from 1100 (default) to 1000
- Lowering both VDDG voltages to 0.950v and VDDP to 0.9v
- Testing load-line calibration on a variety of settings including auto, mode 1, mode 2, mode 3 etc.
- Testing with RAM on XMP profile 1, 2 and default (2400MHz)
- Testing different Ryzen Master recommendations (tried auto overclock, PBO enabled + curve optimizer for -29 on all cores etc).
- Default BIOS settings, PBO disabled, no XMP profile on RAM (2400MHz default) - Cinebench completed 1 full 10 minute multi core test, I started another one for good measure and 2 minutes in I again got a crash but this was better than not being able to run at all
- PBO enabled in BIOS with custom PBO limits: PPT 160, TDC 115, EDC 140 and curve optimizer on -28 for all cores and a +50 MHz boost clock override , RAM on XMP profile 1 -> ran Cinebench fully once, but Premiere Pro still crashed
