So I have had this issue for about year now and its really annoying me. I have 8GB of memory and for some reason half of it is being reserved for hardware. I have tried everything:
- REGEDIT
- MSCONFIG
- Reinstall of windows
- Update BIOS
- Swap ram
- Swap GPU
- Swap Ram slots
So I really don't know what to do with my PC anymore. I know its not bad ram RAM because I swapped it with 4GB and it reduced it to 2GB. The slots work because in the BIOS it reads all 8GB and mem test doesn't detect any error. I even checked CPU-ID and that says everything is fine. The only way I know its limiting is is because it says it in Task Manager. I also notice lack in performance. Is this a hardware issue or one in Windows? Below are my system specs:
- AMD FX 6300
- Gigabyte GA 970A-UD3P
- G.Skill Ripjaw X 2x4 GB
- MSI GeForce GTX 750ti OC
- EVGA 430w PSU
- Windows 10 64bit
- REGEDIT
- MSCONFIG
- Update BIOS
- Swap ram
- Swap GPU
- Swap Ram slots
- AMD FX 6300
- EVGA 430w PSU
- Windows 10 64bit
