[SOLVED] PC resets repeatedly after power on
Dec 26, 2019
Hi guys,
I assembled a new computer with this specifications: Mainboard Asus h310mk, CPU Core i3 8100, ... (i think other specification not relevant to my problem). I install Windows 10 by a bootable USB disk, everything was ok until I install mainboard's driver using it's DVD. after installing drivers, PC resets repeatedly and doesn't boot. ( monitor doesn't turn on)
I have removed mainboard battery and reinserted it, but it can't help.
What should I do? Is this problem related to bios upgrade?
thanks for your help
Maybe.
  1. Boot into the BIOS again to check which BIOS the MB has.
  2. Use onboard iGPU to boot the PC.
  3. You may try to use one stick RAM, if you had more than one.
Latest posts
