PC restart problem, Bad PSU?
XiPH3R
479
My PC tends to restart when i try to play any game. sometimes it happens mid game and sometimes right at launch. Sometimes though it restarts even while watching youtube. it happens 2-3 times a day, and is very frustrating(espacianly during comp matches in csgo). I think its my PSU.
When the PSU that i currently have is a Corsair vs 550. and here's my full specs
CPU: i5 4440
RAM: Corsair vegeance 2 x 4gb
MOBO: Asrock h97 Pro 4
GPU: Sapphire AMD Radeon r9 270x 2gb OC (Going to upgrade to rx 480 the next month)
3 HDDs and 1 SSD
1 Optical drive
I have found a Corsair GS600, going for cheap, should i get it? and what are the other Budget options?
The Seasonic S12II 620W is a good power supply with a Tier - 2 rating. I own the Seasonic S12II 520W PSU and its been working fine for over a year, I did have one PSU Shut Down, never could duplicate the issue so I assume it was an input power problem and so the PSU did its job and protected my computer.
If you want a modular PSU get the M12II from Seasonic, it cost a little more money, but maybe worth it to some people.
So would this be good enough?
Click to open expanded view
SEASONIC S12II SERIES 620W POWER SUPPLY W/80+ BRONZE CERTIFICATION
http://www.amazon.in/dp/B005O8POA4/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3ITOJXBOVZ4HW&coliid=I3MBZUSS319KL7
But prob is its a little over my budget
Btw this is the Corsair PSU that i may get
http://www.amazon.in/Corsair-CP-9020063-WW-GS600-Power-Supply/dp/B00AMLKKT8?ie=UTF8&keywords=corsair%20gs600&qid=1474619347&ref_=sr_1_1&sr=8-1
What your thoughts on this?
The Seasonic S12II is it then, thanks
