My PC restarts it self when I am playing some games that (I suppose) need more graphics power (like Mortal Kombat X, the enter sequence of Tomb Raider or Ori and The blind forest in heavy water sequences but this works if I lower the resolution from 1920p to something like 1080p or 720p).
As per what I have read in Tom's Hardware it is probably a PSU problem. My PC is an 5 years old PC I build my self (first time in my life!) And I tried to do everything correctly but maybe I missed something.
My PC parts are
PSU: be quiet! BN232 Straight Power 10 600W
CPU Cooler: be quiet! Dark Rock Pro 3 CPU Kühler 14 Heatpipes BK019
Case: be Quiet! Silent Base 800 PC ATX Black BG002
CPU: Intel i7-4790K Core Prozessor (4.00 GHz, Max. Turbo 4.4 GHz, Sockel 1150, 8M Cache, 88Watt)
MotherBoard: Gigabyte GA-Z97X-UD3H 1150 Mainboard Sockel (Intel Z97, 4x DDR3 Speicher)
GPU: GIGABYTE GeForce GTX 950 Xtreme Gaming 2GB GDDR5 1
RAM (4): Corsair CML16GX3M2A1600C10 Vengeance Low Profile 16GB (2x8GB) DDR3 1600 Mhz CL10 XMP
SSD 1 (OS): Samsung SSD 860 PRO 1TB
SSD 2 : Samsung SSD 850 EVO 250
HDD 1: ST100DM003-1ER162
HDD 2: ST500DM002-1BS142
I first had just 2 RAM sticks, later I buy 2 more and fixed the voltages because it wasn't booting, but problems like the one with Mortal Kombat already existed.
Currently I use two monitors one with HDMI (1980p) and another one with DisplayPort (1440p), but again the problem with MK happened when I just had the HDMI one.
Any pointers on what I have to test or check will be appreciated.
Thanks!
Update:
As update, I let prime95 run for something like an 1.5 hours (and 15 minutes with 2 instances) and my pc did not crash.
My PC parts are
Thanks!
Update:
