Question Pc running low FPS
Apr 3, 2022
5
Hello, my pc has a ryzen 3700x, Aorus b450 PRO WIFI, 500 watt PSU, and a new rtx 3070 ti I just bought. It used to have a 2060 and just upgraded, but I’m getting the same if not lower FPS than my 2060. I was thinking it might be my PSU not having enough power but I’m not sure.
Your PSU is too weak, regardless of quality, for a 3070ti. You need to get a quality 650w, or higher unit. Did you run DDU, to remove drivers, then reinstall the latest, from Nvidia?
I ordered an 850 watt supply, I just didn’t know if that was the problem or if it was something else. Yes I reinstalled the nvidia drivers, but didn’t use DDU, I just used GeForce experience.
