Question PC shuts down while gaming - - - "Kernel Power 41" error ?
Aug 8, 2024
Hello,
never had problems with my system until today.
Gtx1080
ryzen7 5800x 3d
x370 krait gaming AM4
32 gigs RAM@3200MHz
650w be quiet power zone model Z1 - 650W
Bios Vers. 1.L6 AMD AGESA Combo AM4v2PI 1.2.0.A
It is shutting down while gaming after 10-15mins (GPU 80°C )
(CPU 70-80°C)
Temps didnt change, normal temps while under load for me.
Also tried GPU stress test which leads to the same problem after 10-15 mins
What I find strange is that CPU stress test runs since an hour without shutting down
When my PC turned off I cant restart, nothing is happening when I press the restart button - I have to turn the power supply off and back on to restart
No overclocking
Also tried underclocking RAM to 2666MHz just to be sure its not the Ram speed whatsoever - didnt change a thing
Do u think it is the power supply?
Need help pls
Edited some Hardware Infos
650W power supply
650W is the advertised wattage of the unit. What is the make and model of the PSU and it's age? Make and model of your motherboard? BIOS version for your motherboard?
Its 6 years old I would say (had years of just watching youtube so not everyday under load)
motherboard is x370 krait gaming AM4
It sounds like the PSU might be the issue. How old is it? Aging could cause the shutdowns. Have you checked the Windows Event Viewer for errors around the time of the crashes? Also, can you monitor power draw during gaming? It might be maxing out your PSU. Lastly, any irregular voltage readings in BIOS or with tools like HWMonitor? These could help confirm if the PSU is the problem.
