Question PC started turning itself off and on again while under load, I need help to diagnose the problem
Oct 3, 2024
Hello,
First of all, I'd like to share my specs (everything is stock, with RAM XMP enabled):
CPU i5 11400 (~3 years of use)
GPU RX 6750 XT (~1 year of use)
CPU cooler Scythe Fuma 2 (~3 years of use, I haven't changed the thermal paste since I built the PC)
Motherboard Gigabyte B560m Gaming HD (~3 years of use)
2x8 Gb RAM 3200 MHz (~3 years of use)
PSU Corsair RM650x (~3 years of use)
Windows 11
So, last week I started playing a game called "Satisfactory". I ran into a lot of crashes (once every 5-10 minutes), which I attributed to the fact that the game was a new release. However, one of those times the computer completely shut off and turned on again, which I thought was because the game crashed Windows or something. However, a couple of days ago I tried to run the game again, and the computer turned itself off and on once again. My sister, who sometimes plays League of Legends on my PC, said the same thing happened while she was playing.
My first thought was overheating because my case is awful (I don't even know the model or brand) and has only 2 fans (one lateral intake, one back exhaust), so I ordered a new case online (which hasn't arrived yet). However, a Reddit user (as well as my mom lol) suggested me to open the side panel, point a fan towards my PC and test to see if it shuts down again.
So I tried this idea, I opened OCCT and ran two stress tests: one CPU + GPU, and the other a power test. In both tests, my PC shut down. The temperatures all seemed fine (all CPU cores were at maximum 70-75°C, GPU was also around 75°C, with the only "concerning" temperature being a 102°C hotspot, which is still bellow the maximum acceptable according to AMD).
I decided to look for the .DMP files generated by Windows during these shut downs, and ran WinDbg to find answers. Here are the results:
Log 1:
Code:
NonInteractiveNuget : true
AllowNugetMSCredentialProviderInstall : true
AllowParallelInitializationOfLocalRepositories : true
EnableRedirectToChakraJsProvider : false
-- Configuring repositories
----> Repository : LocalInstalled, Enabled: true
----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.031 seconds
----> Repository : UserExtensions, Enabled: true, Packages count: 0
----> Repository : LocalInstalled, Enabled: true, Packages count: 42
Microsoft (R) Windows Debugger Version 10.0.27704.1001 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\perei\OneDrive\Área de Trabalho\100224-19625-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 22621 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0xfffff804`26800000 PsLoadedModuleList = 0xfffff804`274134f0
Debug session time: Wed Oct 2 19:07:13.195 2024 (UTC - 3:00)
System Uptime: 0 days 2:02:12.766
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000e3`14629018). Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff804`26c16000 48894c2408 mov qword ptr [rsp+8],rcx ss:ffffb681`993759f0=0000000000000101
3: kd> !analyze -v
* Bugcheck Analysis *
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
Arguments:
Arg1: 0000000000000010, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: ffffb681994e2180, The PRCB address of the hung processor.
Arg4: 0000000000000006, The index of the hung processor.
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1906
Key : Analysis.Elapsed.mSec
Value: 9220
Key : Analysis.IO.Other.Mb
Value: 25
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 31
Key : Analysis.Init.CPU.mSec
Value: 234
Key : Analysis.Init.Elapsed.mSec
Value: 29166
Key : Analysis.Memory.CommitPeak.Mb
Value: 97
Key : Analysis.Version.DbgEng
Value: 10.0.27704.1001
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x101
Key : Bugcheck.Code.TargetModel
Value: 0x101
Key : Dump.Attributes.AsUlong
Value: 1008
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Value: Dump completed successfully.
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: CLOCK_WATCHDOG_TIMEOUT_INVALID_CONTEXT_nt!KeAccumulateTicks
Key : Failure.Hash
Value: {95498f51-33a9-903b-59e5-d236937d8ecf}
Key : Stack.Pointer
Value: ISR
BUGCHECK_CODE: 101
BUGCHECK_P1: 10
BUGCHECK_P2: 0
BUGCHECK_P3: ffffb681994e2180
BUGCHECK_P4: 6
FILE_IN_CAB: 100224-19625-01.dmp
DUMP_FILE_ATTRIBUTES: 0x1008
Kernel Generated Triage Dump
FAULTING_THREAD: ffffe587bc8fb080
FAULTING_PROCESSOR: 6
PROCESS_NAME: CpuOcct64.exe
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
STACK_TEXT:
ffffb681`993759e8 fffff804`26c76a38 : 00000000`00000101 00000000`00000010 00000000`00000000 ffffb681`994e2180 : nt!KeBugCheckEx
ffffb681`993759f0 fffff804`26a2edb1 : 00000000`00000000 ffffb681`99380180 00000000`00072930 00000000`00000000 : nt!KeAccumulateTicks+0x247728
ffffb681`99375a50 fffff804`26a2c3bf : 00000000`0000000c 00000000`00001388 00000000`00072900 00000000`000444aa : nt!KiUpdateRunTime+0xd1
ffffb681`99375c00 fffff804`26a2cfa8 : 00000000`00000001 00000000`00000000 ffffb681`99380180 00000000`00000000 : nt!KiUpdateTime+0x63f
ffffb681`99375ea0 fffff804`26a2c86a : fffff804`2745ffe8 00000000`00000001 00000000`00000001 00000000`00000000 : nt!KeClockInterruptNotify+0x228
ffffb681`99375f40 fffff804`26ab76bc : 00000011`12c23f21 ffffe587`a3704e60 ffffe587`a3704f10 00000000`00000000 : nt!HalpTimerClockInterrupt+0x10a
ffffb681`99375f70 fffff804`26c1820a : fffffe8d`55902420 ffffe587`a3704e60 000001ea`0e2dae00 98788844`f78a45a0 : nt!KiCallInterruptServiceRoutine+0x9c
ffffb681`99375fb0 fffff804`26c18ad7 : 00000000`0000002b 00000000`00000000 00000000`0001406f ffffe587`00000000 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffffe8d`559023a0 00007ff6`c804e9fb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
000000e3`150fde30 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff6`c804e9fb
SYMBOL_NAME: nt!KeAccumulateTicks+247728
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
IMAGE_VERSION: 10.0.22621.4169
STACK_COMMAND: .process /r /p 0xffffe587b7a32080; .thread 0xffffe587bc8fb080 ; kb
BUCKET_ID_FUNC_OFFSET: 247728
FAILURE_BUCKET_ID: CLOCK_WATCHDOG_TIMEOUT_INVALID_CONTEXT_nt!KeAccumulateTicks
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {95498f51-33a9-903b-59e5-d236937d8ecf}
Followup: MachineOwner
3: kd> lmvm nt
Browse full module list
start end module name
fffff804`26800000 fffff804`27847000 nt (pdb symbols) C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\C688AAF2BB4DE0FE26E41A66F7E016D21\ntkrnlmp.pdb
Loaded symbol image file: ntkrnlmp.exe
Mapped memory image file: C:\ProgramData\Dbg\sym\ntkrnlmp.exe\64BC99911047000\ntkrnlmp.exe
Image path: ntkrnlmp.exe
Image name: ntkrnlmp.exe
Browse all global symbols functions data Symbol Reload
Image was built with /Brepro flag.
Timestamp: 64BC9991 (This is a reproducible build file hash, not a timestamp)
CheckSum: 00B878AD
ImageSize: 01047000
File version: 10.0.22621.4169
Product version: 10.0.22621.4169
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File type: 1.0 App
File date: 00000000.00000000
Translations: 0409.04b0
Information from resource tables:
CompanyName: Microsoft Corporation
ProductName: Microsoft® Windows® Operating System
InternalName: ntkrnlmp.exe
OriginalFilename: ntkrnlmp.exe
ProductVersion: 10.0.22621.4169
FileVersion: 10.0.22621.4169 (WinBuild.160101.0800)
FileDescription: NT Kernel & System
LegalCopyright: © Microsoft Corporation. All rights reserved.
Log 2:
Code:
************* Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.016 seconds
Loading Dump File [C:\Users\perei\OneDrive\Área de Trabalho\100224-22046-01.dmp]
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Kernel base = 0xfffff800`3d600000 PsLoadedModuleList = 0xfffff800`3e2134f0
Debug session time: Wed Oct  2 19:20:33.954 2024 (UTC - 3:00)
System Uptime: 0 days 0:13:07.625
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
PEB is paged out (Peb.Ldr = 000000b0`f7e52018).  Type ".hh dbgerr001" for details
nt!KeBugCheckEx:
fffff800`3da16000 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:ffff9700`2b5249f0=0000000000000101
1: kd> !analyze -v
Arguments:
Arg3: ffff97002b8a9180, The PRCB address of the hung processor.
Arg4: 0000000000000007, The index of the hung processor.
Debugging Details:
    Value: 1843
    Value: 3146
    Value: 0
    Value: 0
    Value: 0
    Value: 203
    Value: 13206
    Value: 96
    Value: 1.2408.27.1
    Value: 0x101
    Value: 0x101
    Value: 1008
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Key  : Stack.Pointer
    Value: ISR
BUGCHECK_CODE:  101
BUGCHECK_P1: 10
BUGCHECK_P2: 0
BUGCHECK_P3: ffff97002b8a9180
BUGCHECK_P4: 7
FILE_IN_CAB:  100224-22046-01.dmp
FAULTING_THREAD:  ffffd60fd72e0080
FAULTING_PROCESSOR: 7
BLACKBOXWINLOGON: 1
PROCESS_NAME:  Discord.exe
STACK_TEXT:
ffff9700`2b5249e8 fffff800`3da76a38     : 00000000`00000101 00000000`00000010 00000000`00000000 ffff9700`2b8a9180 : nt!KeBugCheckEx
ffff9700`2b5249f0 fffff800`3d82edb1     : fffff780`00000350 ffff9700`2b50a180 00000000`0000c4e7 00000000`00000000 : nt!KeAccumulateTicks+0x247728
ffff9700`2b524a50 fffff800`3d82c3bf     : 00000000`0000000c 00000000`00001388 00000000`0000c400 00000000`0000755d : nt!KiUpdateRunTime+0xd1
ffff9700`2b524c00 fffff800`3d82cfa8     : 00000000`00000000 00000000`00000000 ffff9700`2b50a180 00000000`00000000 : nt!KiUpdateTime+0x63f
ffff9700`2b524ea0 fffff800`3d82c86a     : fffff800`3e25ff40 00000000`00000001 00000000`00000001 00000000`0000000c : nt!KeClockInterruptNotify+0x228
ffff9700`2b524f40 fffff800`3d8b76bc     : 00000001`d58cfd73 ffffd60f`c45375a0 ffffd60f`c4537650 00000000`00000000 : nt!HalpTimerClockInterrupt+0x10a
ffff9700`2b524f70 fffff800`3da1820a     : ffff920c`79386a00 ffffd60f`c45375a0 ffff9700`2b50a180 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x9c
ffff9700`2b524fb0 fffff800`3da18ad7     : 00000000`0d823af3 ffffe642`4ec6762e ffffe78b`03bf78b0 fffff800`3d8336eb : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
ffff920c`79386980 fffff800`3d837696     : 00000000`00000000 00000000`00000000 00000000`00000000 fffff800`3d9023f0 : nt!KiInterruptDispatchNoLockNoEtw+0x37
ffff920c`79386b10 fffff800`3d8374a5     : ffff920c`79386d00 ffffd60f`da904640 ffff920c`793870a0 ffff920c`79386c50 : nt!KiIpiStallOnPacketTargetsPrcb+0x16
ffff920c`79386b40 fffff800`3dd89fea     : ffff920c`79386d00 ffffd60f`d72e0080 000000b0`f87fc820 ffffd60f`da8ac180 : nt!KeFlushProcessWriteBuffers+0xd9
ffff920c`79386b90 fffff800`3dd23147     : ffffd60f`da8ac180 00000000`00000000 ffff920c`79387420 000000b0`f87fc820 : nt!PsQueryTotalCycleTimeProcess+0x2a
ffff920c`79386bc0 fffff800`3da2b605     : ffffe642`4dcd4dd0 00000000`00000000 ffffe78a`fe48f8e8 00000000`00000000 : nt!NtQueryInformationProcess+0x1b57
ffff920c`79387330 00007ffe`bb310454     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
000000b0`f87fc7e8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`bb310454
MODULE_NAME: nt
STACK_COMMAND:  .process /r /p 0xffffd60fda8ac180; .thread 0xffffd60fd72e0080 ; kb
OSNAME:  Windows 10
So, I ask you, guys: Could anyone with more experience read those logs and find a diagnose? Thank you in advance.
On the power supply to the GPU are you using both 8 pin cables or an 'extension' type with one cable, two connectors?
Those temps are concerning to me.
I am no help with the logs.
Hello, I'm using both cables, I read that using the "extension" with two connectors might be insufficient for the GPU.
Are the temps that bad? I live in a hot country (Brazil), so I expected the temps might be a bit higher than the usual NA/EU user, but I read that the max acceptable temperature for my CPU is 100°C, which is much higher than I achieved. Also, the GPU reaches 75°C, which is bellow the max temperature, and the hotspot of 102°C is high, but still bellow AMD's max of 110°C.
Glad to hear on the power connector.
When your PC is on idle, are you over 20* above ambient for the room? Yes, here in the SE US we do not deal with the same temps.
What power plan are you using?
Keeping the PC clean of dust?
I think my components stay within the 20°C threshold, they might stay above it for a few minutes after a stress test but I don't think this counts as "idle"
I think I'm using the higher performance option in the Control Panel, but I'm not home to verify this.
Also, I haven't cleaned my PC in quite some time, it's probably full of dust.
