Hi guys
Hope you are all well!
Was wondering if any of you kind souls could help me with a problem please:
I spilt some water on my desktop tower last week and some went over the motherboard and psu fan.
I dried it as best as I could and turned it on after a few days. The USB ports weren’t working, nor was it connecting to the screen (display is plugged into the gpu). Sometimes the screen would connect and it wouldn’t progress beyond the bios, sometimes it would go to the miscosoft blue screen of death.
However if I turned it on and off about 6 times, on the off chance, it would work and I could use the pc normally.
Last night, I was awoken to my pc turning itself on and off constantly every 3 seconds, the way it would turn off suggested power shortage which makes me think psu, but why would the pc turn itself on?
Does anyone have any suggestions? PSU fault? Motherboard fault? Is a component still wet? Should I take it to a store for them to check it out before I commit to buying a component?
Would really appreciate some help, thanks so much for reading!
