Hello, looking to upgrade some parts of my PC before the release of Cyberpunk. I wasnt looking for a complete build replacement but if needed I can save.
Current Specs:
GPU: 2060 Super 8gb
CPU: Intel Core i7 7700k
RAM: 16gb DDR4
Mobo: unsure but I know it cant go higher then the i7, so that would probably need to be replaced
I was thinking of getting some expensive cooling and over clocking? maybe that would cover me until I can save to potentially move over to Ryzen. Or I was looking at getting
Cooler Master MasterLiquid ML120L RGB Liquid CPU Cooler
AMD Ryzen 7 3800XT 3.9GHz 8 Core (Socket AM4) CPU
MSI B450 TOMAHAWK MAX AMD Socket AM4 Motherboard
and then another 16gb of ram to make it 32gb
In terms of budget probably around 400-500 mark. Cheers
Current Specs:
GPU: 2060 Super 8gb
RAM: 16gb DDR4
