PC Watercooling Pump Won't Move Coolant
Noodles79
Commendable
Apr 1, 2016
15
So after a while of being a PC enthusiast, I finally decided to tying hardline tubing for a watercooling system I build. Everything went well up until the point I put my fluid in my res. I am using a D5 pump and when I power on the system the pump is clearly running (it hums and creates ripples in the coolant) but the pump doesn't want to move the coolant to any other components in the system. I don't know what the problem is and thanks to anyone in advance for helping.
Check the pins on the Molex plug for the pump, did they get pushed back into the connector and not making good contact? On my old D5, I had to fix this because the pins didn't seat well.
If the pump was 'working' and making noise and turbulence, it means it was getting power. Even if the pump got burned up, you would still hear something. Sounds like the power connection might be in question. Can you check that?
That doesn't seem to make any sense - the pump was previously working but now does not all the sudden? Was it run dry or without coolant?
Without having another power supply or another pump, it's hard to troubleshoot but at this point it sounds like you have a dead pump, but D5's are pretty resilient so I question how 'dead' it actually is.
I've heard that if you put the pwm cable in the motherboard and the molex to the power supply the pump would automatically be in a really slow speed so that might be why the fluid isnt moving. If you have a pwm head on your molex cable i would put both cables directly to the psu because then it is going to go at full speed. This is only temporary until you got the fluid all in the system, then you can move the pwm cable back to a fan header on the motherboard and go into bios and adjust the speed and bumb it up a notch. This might not be the problem at all but its worth a try, to me it sounds more like a defect pump.
I took another working power supply from an older PC and the pump still does not work. Also I never ran the pump dry and made sure I didn't. At this point I'm 99% sure the pump is dead and I will have to order a new one later tonight. Thank you so much for help.
