Question PC won't enter sleep when idle
Dreadmyst
24
My Logitech g910 orion keyboard died and I replaced it with a Corsair K55. After installing Corsairs software I can't seem to get my machine to enter sleep mode when it's supposed to be idle. I have double-checked to make sure that the ethernet adapter and wifi adapter are not able to wake the PC. I have even tried to disable the Corsair service that iCUE installs, and nothing. I've even disabled many non-essential services that were running. The monitors will turn off after the idle time is set but the system will not enter sleep unless I go into the start menu power options and tell it to sleep. If I tell it to sleep it will sleep with no issues but it won't idle sleep. Any ideas or suggestions on how to fix this would be greatly appreciated. I'm tempted to go buy a new keyboard if this is a Corsair software issue.
Certainly try a different keyboard before buying a new one.
I had a mouse that would interrupt screen savers and sleep, but it was a cheap mouse. Something was wrong with it's optical sensor.
Maybe something is wrong with your keyboard or USB.
