So basically a continuation of the issues I had the last few months.
I just got a new 3060 TI OC replacement GPU from overclockers because the 750watt PSU I bought from scan a few months ago was faulty and it fried my old 3060 TI amongst other hardware too so I had to RMA my old Zotac 3060 TI.
So anyway, the current system I am using is this.
MOBO: ga-a320m-sh
CPU: Ryzen 5 3500x
PSU: Corsair rm550x
32gb DDR4 (2X 16gb)
GPU: GTX 1650
1X m.2 ssd
3X ssd 1 external and 2 internal
1X internal HDD
1X external HDD
Internal wireless card
Windows 11
So basically I put the new 3060 TI into my system and pressed power button and nothing happened. All what happened was the front 3 stack RGP fans lit up for a split millisecond and then nothing. So I then turned the power button off on the back of the PC and unplugged the cable and then plugged back in and turned the power button back on, and tried again, and again it did the same thing, I tried this multiple times.
So the thing is this card is this one: Asus GeForce RTX 3060Ti Dual OC 8GB GDDR6X PCI-Express Graphics Card
My old card was the Zotac 3060 TI Twin edge. The new Asus card has 2X 2+6pin slots on it, So because my PSU only has 2 8pin slots on it, 1 is for CPU and 1 is for GPU. I had to daisychain so that both the 8pin slots was plugged into with the same cable. The old Zotac 3060 TI only had 1 8pin slot on the card though.
So I was like great, a issue I have had in the past few months of my pc not even powering on at all.
So I then put my GTX 1650 card back in and the PC powered on fine without any issues. This is the setup I have now used the last 6 weeks.
I do not know what else to do now. I have not tried to put it in again yet. Maybe it was just a reseating issue. But I really do not know, I am more leaning towards the 8pin cable could be faulty, maybe the 750watt PSU broke that 8pin cable. I do not have a spare 8 pin cable either. This 8pin cable came with this PSU. It was the only one I have too.
Any help would be appreciated.
Thanks in advance
MOBO: ga-a320m-sh
CPU: Ryzen 5 3500x
PSU: Corsair rm550x
32gb DDR4 (2X 16gb)
GPU: GTX 1650
1X m.2 ssd
1X internal HDD
1X external HDD
Windows 11
Thanks in advance
