PCI-E Wireless Adapter Slower than Internet Sharing Through Laptop
WhoopAss_McGue
Commendable
Jan 26, 2017
8
I have a desktop and a laptop computer. The connection on my desktop's old PCI-E wireless adapter was crap, and I assumed it was just a bad card so have been using my laptop to connect instead and connected it to the desktop via an ethernet cable.
I decided to get a new card which arrived today and it has a fairly poor speed as well. Not as bad as the old adapter but still noticeably worse than the laptop. So if anyone could help me fix this I'd be very happy.
Some info:
Laptop model is Acer Aspire V5-431
Desktop wireless adapter is TP-Link Archer T9E (Using Broadcom driver version 7.35.333.0)
The desktop and laptop are sitting right next to each other, and the desktop case is not between the antenna and the router so they should have the same signal strength. The router is using both 2.4 and 5Ghz and I think both computers are capable of receiving both.
Internet Sharing connection speed:
Wireless Adapter speed:
Desktop DxDiag:
System Information
Time of this report: 5/14/2017, 04:20:11
Machine name: THECOMPUTER
Machine Id: {79985752-7A04-4B4A-8A81-285C5A5015BD}
Operating System: Windows 10 Pro 64-bit (10.0, Build 14393) (14393.rs1_release_sec.170427-1353)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 01/07/16 20:59:32 Ver: 05.0000B
Processor: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz (4 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16300MB RAM
Page File: 7201MB used, 10121MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.14393.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 1070
Manufacturer: NVIDIA
Chip type: GeForce GTX 1070
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_1B81&SUBSYS_119D10DE&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 16269 MB
Dedicated Memory: 8119 MB
Shared Memory: 8149 MB
Current Mode: 2560 x 1440 (32 bit) (120Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: ROG PG278QR
Monitor Id: AUS27B1
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: Displayport External
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvldumdx.dll
Driver File Version: 22.21.0013.8189 (English)
Driver Version: 22.21.13.8189
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.1
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 19/04/2017 01:00:00, 885032 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71E3E-58C1-11CF-936C-90311BC2DB35}
Vendor ID: 0x10DE
Device ID: 0x1B81
SubSys ID: 0x119D10DE
Revision ID: 0x00A1
Driver Strong Name: oem84.inf:0f066de361866ac3:Section088:22.21.13.8189😛ci\ven_10de&dev_1b81
Rank Of Driver: 00D12001
Video Accel:
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2)
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
Sound Devices
Description: Speakers (Logitech G633 Gaming Headset)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_046D&PID_0A5C&REV_1001&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 10.00.14393.0000 (English)
WHQL Logo'd: Yes
Date and Size: 08/12/2016 00:00:00, 132096 bytes
Other Files:
Driver Provider: Logitech
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: ROG PG278QR (High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0083&SUBSYS_10DE119D&REV_1001
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
WHQL Logo'd: Yes
Date and Size: 15/07/2016 00:00:00, 410624 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (Logitech G633 Gaming Headset)
Default Sound Capture: Yes
Default Voice Capture: Yes
Date and Size: 7/16/2016 12:41:52, 132096 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Gaming Keyboard G910
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC335
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: G500s Laser Gaming Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC24E
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Logitech G633 Gaming Headset
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0x0A5C
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (xHCI)
| Vendor/Product ID: 0x8086, 0xA12F
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 7/16/2016 12:41:55, 535904 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 7/16/2016 12:41:55, 169312 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 8/6/2016 04:47:49, 38400 bytes
| | | Driver: hidclass.sys, 10/15/2016 04:55:50, 156672 bytes
| | | Driver: hidparse.sys, 8/6/2016 04:46:37, 40960 bytes
| | +-+ Logitech G500s Gaming Mouse
| | | | Matching Device ID: hid\vid_046d&pid_c24e&mi_00
| | | | Lower Filters: LGSHidFilt
| | | | Service: mouhid
| | | | Driver: LGSHidFilt.Sys, 5/30/2013 17:16:40, 64280 bytes
| | | | Driver: mouhid.sys, 7/16/2016 12:41:54, 32256 bytes
| | | | Driver: mouclass.sys, 7/16/2016 12:41:54, 59232 bytes
| | | | Driver: LkmdfCoInst.dll, 5/31/2013 20:19:12, 1843480 bytes
| | | Service: HidUsb
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 9/15/2016 17:43:23, 39424 bytes
| | | | Driver: kbdclass.sys, 7/16/2016 12:41:54, 62304 bytes
| | Service: usbccgp
| | | Service: HidUsb
| | | | Service: kbdhid
| | | Service: HidUsb
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
| Vendor/Product ID: 0x046D, 0xC232
| Service: kbdhid
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC231
| Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| Service: mouhid
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 280.1 GB
Total Space: 476.8 GB
File System: NTFS
Model: OCZ-AGILITY3
Drive: E:
Free Space: 3165.2 GB
Total Space: 5723.0 GB
File System: NTFS
Model: ST6000DM004-2EH11C
Drive: F:
Free Space: 2300.1 GB
Total Space: 4769.2 GB
File System: NTFS
Model: Seagate Expansion Desk USB Device
Drive: D:
Model: ATAPI iHES112 3
Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:53, 173056 bytes
System Devices
Name: TP-LINK 802.11ac Network Adapter
Device ID: PCI\VEN_14E4&DEV_43A0&SUBSYS_061914E4&REV_03\4&1D02AF65&0&00E4
Driver: C:\Windows\system32\DRIVERS\bcmwl63a.sys, 7.35.0333.0000 (English), 11/30/2015 20:31:52, 11758840 bytes
Driver: C:\Windows\system32\bcmihvsrv64.dll, 7.35.0333.0000 (English), 11/30/2015 20:31:04, 4134912 bytes
Driver: C:\Windows\system32\bcmihvui64.dll, 7.35.0333.0000 (English), 11/30/2015 20:31:20, 3779584 bytes
Name: Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #9 - A118
Device ID: PCI\VEN_8086&DEV_A118&SUBSYS_86941043&REV_F1\3&11583659&0&E8
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.14393.0594 (English), 12/14/2016 06:18:10, 335712 bytes
Name: Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #1 - A110
Device ID: PCI\VEN_8086&DEV_A110&SUBSYS_86941043&REV_F1\3&11583659&0&E0
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_A13A&SUBSYS_86941043&REV_31\3&11583659&0&B0
Driver: C:\Windows\system32\DRIVERS\TeeDriverW8x64.sys, 11.00.0000.1160 (English), 7/28/2015 20:37:20, 184608 bytes
Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901
Device ID: PCI\VEN_8086&DEV_1901&SUBSYS_86941043&REV_07\3&11583659&0&08
Name: ASMedia USB3.1 eXtensible Host Controller
Device ID: PCI\VEN_1B21&DEV_1242&SUBSYS_86751043&REV_00\4&27259A83&0&00E0
Driver: C:\Windows\system32\DRIVERS\asmtxhci.sys, 1.16.0026.0001 (English), 6/5/2015 14:13:28, 442104 bytes
Name: Intel(R) 100 Series/C230 Series Chipset Family LPC Controller - A145
Device ID: PCI\VEN_8086&DEV_A145&SUBSYS_86941043&REV_31\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:53, 18784 bytes
Name: Intel(R) 100 Series/C230 Series Chipset SMBus - A123
Device ID: PCI\VEN_8086&DEV_A123&SUBSYS_86941043&REV_31\3&11583659&0&FC
Driver: n/a
Name: Intel(R) Ethernet Connection (2) I219-V
Device ID: PCI\VEN_8086&DEV_15B8&SUBSYS_86721043&REV_31\3&11583659&0&FE
Driver: C:\Windows\system32\DRIVERS\e1d65x64.sys, 12.13.0017.0007 (English), 4/19/2016 23:18:40, 559080 bytes
Driver: C:\Windows\system32\e1d65x64.din, 4/7/2016 02:36:28, 3130 bytes
Driver: C:\Windows\system32\NicCo4.dll, 4.02.0003.0000 (English), 4/19/2016 23:18:40, 151872 bytes
Driver: C:\Windows\system32\NicInstD.dll, 9.12.0013.0000 (English), 4/19/2016 23:18:40, 118264 bytes
Driver: C:\Windows\system32\e1dmsg.dll, 10.00.0417.0000 (English), 4/19/2016 23:18:40, 102952 bytes
Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_A12F&SUBSYS_86941043&REV_31\3&11583659&0&A0
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.14393.0000 (English), 7/16/2016 12:41:55, 381792 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_8086&DEV_191F&SUBSYS_86941043&REV_07\3&11583659&0&00
Driver: n/a
Name: Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #5 - A114
Device ID: PCI\VEN_8086&DEV_A114&SUBSYS_86941043&REV_F1\3&11583659&0&E4
Name: Intel(R) 100 Series/C230 Series Chipset Family PCI Root Port #17 - A167
Device ID: PCI\VEN_8086&DEV_A167&SUBSYS_86941043&REV_F1\3&11583659&0&D8
Name: NVIDIA GeForce GTX 1070
Device ID: PCI\VEN_10DE&DEV_1B81&SUBSYS_119D10DE&REV_A1\4&2D78AB8F&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 456824 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 4/20/2017 02:59:14, 1375172 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\NvContainerSetup.exe, 1.00.0007.0000 (English), 4/20/2017 02:59:14, 4186224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\NvCplSetupInt.exe, 1.00.0007.0000 (English), 4/20/2017 02:59:14, 100724840 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 4/20/2017 02:59:14, 19064 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 220152 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 143896 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 4/20/2017 02:59:14, 19064 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 263584 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 172248 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 4/1/2017 04:27:00, 27203 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 4/20/2017 02:59:14, 848504 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 414840 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 4/20/2017 02:59:14, 77145 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.8189 (English), 4/20/2017 02:59:14, 450496 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.8189 (English), 4/20/2017 02:59:14, 858560 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 2.00.0004.0000 (English), 4/20/2017 02:59:14, 418752 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 2.00.0004.0000 (English), 4/20/2017 02:59:14, 513144 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvlddmkm.sys, 22.21.0013.8189 (English), 4/21/2017 01:31:20, 14847088 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvd3dumx.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 16895368 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvd3dumx_cfg.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 17257576 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvinitx.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 196152 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvldumdx.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 885032 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvoglshim64.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 172736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvumdshimx.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 607456 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvwgf2umx.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 24712592 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvwgf2umx_cfg.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 25435128 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 1054144 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 960632 bytes
Driver: C:\Windows\system32\NvIFROpenGL.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 609912 bytes
Driver: C:\Windows\system32\nv-vk64.json, 4/1/2017 04:27:00, 669 bytes
Driver: C:\Windows\system32\nvDecMFTMjpeg.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 821184 bytes
Driver: C:\Windows\system32\nvEncMFTH264.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 1278712 bytes
Driver: C:\Windows\system32\nvEncMFThevc.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 1275944 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 776048 bytes
Driver: C:\Windows\system32\nvapi64.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 4085712 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 40201152 bytes
Driver: C:\Windows\system32\nvcuda.dll, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 11111392 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.8189 (English), 4/20/2017 02:59:14, 3789248 bytes
Driver: C:\Windows\system32\nvfatbinaryLoader.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 688968 bytes
Driver: C:\Windows\system32\nvinfo.pb, 4/20/2017 02:59:14, 43956 bytes
Driver: C:\Windows\system32\nvmcumd.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 618928 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 35354232 bytes
Driver: C:\Windows\system32\nvopencl.dll, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 10635008 bytes
Driver: C:\Windows\system32\nvptxJitCompiler.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 11056272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvd3dum.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 13687472 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvd3dum_cfg.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 13985624 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvinit.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 168640 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvldumd.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 727632 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvoglshim32.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 143920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvumdshim.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 492768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvwgf2um.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 20828152 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\nvwgf2um_cfg.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 21664488 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 990328 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 911296 bytes
Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 499136 bytes
Driver: C:\Windows\SysWow64\nv-vk32.json, 4/1/2017 04:27:00, 669 bytes
Driver: C:\Windows\SysWow64\nvDecMFTMjpeg.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 651200 bytes
Driver: C:\Windows\SysWow64\nvEncMFTH264.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 995736 bytes
Driver: C:\Windows\SysWow64\nvEncMFThevc.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 993872 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 612088 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 3602112 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 35280320 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 9316648 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0013.8189 (English), 4/20/2017 02:59:14, 3246200 bytes
Driver: C:\Windows\SysWow64\nvfatbinaryLoader.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 577728 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 28590712 bytes
Driver: C:\Windows\SysWow64\nvopencl.dll, 6.14.0013.8189 (English), 4/20/2017 02:59:14, 8876456 bytes
Driver: C:\Windows\SysWow64\nvptxJitCompiler.dll, 22.21.0013.8189 (English), 4/20/2017 02:59:14, 9014976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_274d0ab8ee30c459\VulkanRT-Installer.exe, 1.00.0042.0001 (English), 4/20/2017 02:59:14, 775488 bytes
Driver: C:\Windows\system32\nvdispco6438189.dll, 2.00.0048.0004 (English), 4/20/2017 02:59:14, 1988216 bytes
Driver: C:\Windows\system32\nvdispgenco6438189.dll, 2.00.0023.0002 (English), 4/20/2017 02:59:14, 1589880 bytes
Name: Intel(R) 100 Series/C230 Series Chipset PMC - A121
Device ID: PCI\VEN_8086&DEV_A121&SUBSYS_86941043&REV_31\3&11583659&0&FA
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_A170&SUBSYS_86911043&REV_31\3&11583659&0&FB
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:52, 83456 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:52, 97280 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:52, 366592 bytes
Name: Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_A102&SUBSYS_86941043&REV_31\3&11583659&0&B8
Driver: C:\Windows\system32\DRIVERS\iaStorA.sys, 14.06.0000.1029 (English), 7/29/2015 12:44:00, 1462720 bytes
Device ID: PCI\VEN_10DE&DEV_10F0&SUBSYS_119D10DE&REV_A1\4&2D78AB8F&0&0108
I split the 2/5Ghz into separate networks and this seems to have fixed the issue! However the T9E description on Amazon mentioned using "combined" speeds with both GHz settings so I'm wondering if there's a way to configure it to use both to get the most out of it? I also set the 5Ghz channel width to 20/40/80MHz in the router's settings and set the adapter to a 80Mhz channel, not sure if that's a good thing to do so again help is appreciated.
New adapter speed test:
