PCI express freq to 100mhz? or Auto?
jincuteguy
160
So after reading the overclocking guide they mentioned if you overclocked your CPU which will be most likely make the FSB higher (in my case from 333mhz stock to 400mhz), you also have to set the PCI express frequency to 100mhz instead of Auto in the bios? so that you won't burn the graphic card . Or is it still ok if I just leave the PCI express frequency at "Auto" in the bios?
Asus P5K/EPU board
E6750 at 3.2ghz (400mhz FSB)
2G Crucial Ballistix Memory 5-5-5-18 (2x400mhz = 800)
Not likely if you are OCing. I have mine set to 33.33MHz and my frames have actually increased (obviously due to the increased processor speeds).
I dont think I can set the PCI express to 33mhz, minimum is 100 man so I think u talking about the PCI normal port like for sound card , NIC card.
33.33MHz for the PCI. 100MHz for the PCI-E. There's a difference between the two.
It could be. If you don't know what you're doing, lock it to 100MHz. If the vidcard can't handle it, it may burn to death. Also, there may be data corruption by setting it too high.
MSI states on their site that 120MHz is the max. I would stay under 115Mhz, but I did some benchmarks and there was no difference on my 8800GTS 320MB.
so there's no differnce in game performance between 100mhz and 120mhz? or even 150mhz? Also why do u guys want to set it at 100mhz? is that the default speed for all the new video cards such as 8800GT, 8800GTS 512mb, 8800GTX and ultra?
I did some tests before. From the default 100MHz, which is what all vidcards are designed to run at, I set it to 115MHz. 3Dmark06 jumped by 10points, after running it 10times and taking the avg of course.
10points increase in 3dmark means nothing in real games, and I did not see any boost. I did find out that OCing improved some by increasing the PCI-E frequency, but the gains were only that, 10points.
Upping the frequency on the PCI-E bus might help eventually, or with an SLi/Crossfire setup of PCIe 2.0 cards running in PCI-E 1.1 x8 slots, but be certain to stay well clear of 125Mhz, at that speed SATA controllers start acting up.
For a single card setup, you wont see any improvements.
Here you go (found your testing :) ):
http://www.tomshardware.com/forum/245190-29-pcie-frequency-safe-overclock
Oh yeah, haha, thanks Shadow. I was too lazy to look for it. :)
I'm thinking while this maybe so for my 8800GTS 320MB, it could have better performance gains on, say, a 8800GTS 512MB.
