[SOLVED] PCIe speed - Bifurcation
Hi guys,
I'm currently using a Asus Rampage IV Formula with a xenon e5-1650, and just bought a Asus Hyper x16 m.2 adapter.
The adapter works like a riser card for 4 m.2 cards, and should run at x4x4x4x4.
After buying everything I noticed my mobo won't let me adjust the bifurcation, so only one card is detected.
I now went ahead and tried nodding the bios and changed the bifurcation, but I can still only see 1 stick.
Is there any app which shows you what bifurcation it is running at?
I want to know if my bios mod worked in the first place.
Thanks!
Compatible motherboard models for the HYPER M.2 X16 CARD are published by Asus:
ROG RAMPAGE VI EXTREME
ROG RAMPAGE VI APEX
ROG STRIX X299-XE GAMING
ROG STRIX X299-E GAMING
PRIME X299-DELUXE
PRIME X299-A
TUF X299 MARK 1
TUF X299 MARK 2
Thanks Calvin, but with a little bit of nodding it is possible for other motherboards as well.
It works now for me, I just had to make all pages in the bios visible and I could then change it, also needed to add a nvme module to it from the x299 module. If anyone is interested in the solution please let me know.
