Question Persistent issues with BSODS
Oct 24, 2019
I have had BSODS since December with a PC I had built in November, after losing my whole setup to a coolant leak. The person who built it investigated my issues pretty poorly and just replaced the RAM when I reported the BSODS to them. So I’m just trying to solve things on my own. I have had over 70 BSODS since then and taken a photo of my screen of all that I could catch.
  • Run SFC and DISM checks
  • Reset my PC multiple times
  • RAM replaced
  • Checked that the hardware components are correctly seated
  • Ensured all drivers are fully up to date
  • Updated the BIOS
  • Installed windows on my other SSD (currently running now)
  • Tested a different GPU and still received a BSOD
  • Run stress tests of the GPU and CPU
  • Monitored temperatures
  • Called a PC repair shop who suggested installing on the other SSD (which I've done) or perhaps having the m'board replaced (this was over the phone advice)
  • Posted my minidump files and issues to the Microsoft support site, with their crappy support staff not responding to me beyond a couple of replies
Here is the link to the latest minidump and my system file info together:
https://drive.google.com/drive/folders/1bReElqglZhqXotcA5HpXWTbnrkomiwYc?usp=sharing
Some other issues:
-connection to monitors is lost randomly and can't be brought back, PC is still lit up, sometimes this includes audio freezing and a buzzing sound
-connection to monitors is also consistently lost every time I close FiveM and requires me to force shut down my PC
-computer won't wake back up from sleep, requires a force shut down
I would GREATLY appreciate some insight. WhoCrashed gives me quite a lot of non-specific information.
<3
Thank you
Quick dump look, further analysis necessary: Def some odd errors
Errors:
100219-15156-01
SYSTEM_SERVICE_EXCEPTION (3b)
PROCESS_NAME: Registry
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
100219-12406-01
UNEXPECTED_KERNEL_MODE_TRAP (7f)
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
100119-9593-01
MEMORY_MANAGEMENT (1a)
PROCESS_NAME: chrome.exe
MODULE_NAME: nt
IMAGE_NAME: memory_corruption
10119-9796-01
102419-8031-01
PROCESS_NAME: WmiPrvSE.exe
MODULE_NAME: nt
102419-8375-01
MODULE_NAME: nt
122618-9828-01
BAD_SYSTEM_CONFIG_INFO (74)
PROCESS_NAME: ntoskrnl
IMAGE_NAME: ntoskrnl
122618-6968-01
IRQL_NOT_LESS_OR_EQUAL (a)
122718-13906-01
CRITICAL_PROCESS_DIED (ef)
For 100xxx-xxxx-01 dmps
OSBUILD: 18362
OSSERVICEPACK: 356
For 122xxx-xxxx-01 dmps
OSBUILD: 17763
HARDWARE: (Current)
BaseBoardManufacturer = ASRock
BaseBoardProduct = B450M-HDV
BiosMajorRelease = 5
BiosMinorRelease = 14
BiosVendor = American Megatrends Inc.
BiosVersion = P3.10
BiosReleaseDate = 06/21/2019
Processor Version AMD Ryzen 5 2600 Six-Core Processor
Processor Voltage 8bh - 1.1V
External Clock 100MHz
Max Speed 3900MHz
Current Speed 3400MHz
MEMORY:
Data Width .................................64 bits
Size ................................................8192MB
Bank Locator............................. P0 CHANNEL A (also channel B)
Memory Type............................1ah - Specification Reserved
Type Detail .................................4080h - Synchronous
Speed ........................................... 2400MHz
Manufacturer............................ Unknown
Serial Number
Asset Tag Number...................[String Not Specified]
Part Number .............................CL17-17-17 D4-2400
MODULES:
amdgpio2.sys....................Nov 12 2018
amdgpio3.sys...................Mar 14 2016
amdkmpfd.sys.................Mar 20 2019
AMDPCIDev.sys.............Apr 12 2018
amdpsp.sys.......................Jun 5 2017
AMDRyzenMasterDriver.sys.....Nov 14 2017
AtihdWT6.sys.................Jul 16 2019
atikmdag.sys...................Sep 10 2019
atikmpag.sys...................Sep 10 2019
wdcsam64.sys.................Oct 9 2015
Just some thoughts, I hope the experts chime in for you:
Memory manufacturer? Can't tell if craptastic or known good . Ryzen is memory sensitive
Try clocking your memory down further to 2133 and check stability.
Not stable? Test with 1 DIMM in system, then the other.
Power supply not specified.
Motherboard a possibility after ram. Would need to swap to check.
Latest posts
