Phenom II x4 955 Overclock Help
NachoEmerson
40
I overclocked my cpu using amd overdrive inside of the CCC and I was wondering if this overclock is ok, im not to sure how to overclock a cpu, heres a pic in cpuz
First off lose AMD overdrive, uninstall it is a bunk program full of bugs....OC using the BIOS only...It is quite "easy" on that CPU.....BTW that OC is horrible voltage is way up ...Hell you could get it to 4.0 GHz at that voltage...
Hi there
I've got my 955 clocked at 3.5Ghz on multiplier alone
But like was said above stick to bios not software
Looks good to me, you can prob even turn it up a bit if you have aftermarket cooling. My 955 rig will go to 3.8 Ghz, with an AC 7 pro CPU cooler. Just keep it stable. If it starts glitching, turn your speed back down!
you got pretty low clocks and pretty high voltage like others said.
my C2 955 is running smooth at 3.7GHz with 1.3875v. I just cannot get it stable over 3.7 no matter what voltage I set it to.
my HT and NB I always OC through the BIOS but for the CPU I use K10STAT now to set my own Power State Steps and it works perfect.
power state step 1) 800MHz @ .9v
step 2 & 3) 3.2GHz @ 1.25v
step 4) 3.7GHz @ 1.3875
NB: 2600MHz @ 1.2625v
HT: default
this is with a Hyper212+ cooler and it stays below 45° no matter what's goin on, usually in the 30s though. before on my stock cooler I had it at 3.6GHz with 1.365v and it got up to 58° sometimes during serious gaming and stress tests. with the stock cooler 3.7GHz just got too hot for me too fast.
I have a Hyper212+ already but Im not looking for a big overclock just something small. Her'es what I came up with, look good?
Also when I changed the voltage it turned purple not red I was mistaken
@GObonzo---> Yeah K10STAT does work well for a software power save and OC tool...The GUI isn't the best and can be confusing when setting p-states for a beginner...but yes K10STAT I do trust as a reliable softOC tool.
@Nacho...yeah purplish blue is the safe zone..I may be color blind though..BTW...I see you got it at the proper voltage now thats good
looks like a nice safe overclock. if it's a C3 Revision Phenom 955 there's a good chance you can get the voltage even lower resulting in even lower temperatures (and lower power bill, lol). what temps are you getting now?
are you planning on overclocking your North Bridge at all? it raised WEI scores a few points after reaching 2600+MHz.
Yeah the NB OC will increase performance to good degree just don't surpass 2800 MHz...Voltage should be between 1.1 and 1.25v..I stick to 1.2v on the NB and HT...My NB is at 2800 MHz@1.2v and HT is at 2600 MHz@1.2v...NB OCing should be your final component to OC after all else is stable
Just looking at your board's UEFI BIOS, pretty cool setup. Seems much better design than the one my ASRock has.
Looks like about the middle of the "Advanced Mode, Ai Tweaker" page you'll see CPU/NB Frequency. Values should change the same as the CPU multiplier, just type in value you want. I see lots of people nowadays showing 3000MHz NB but I've never been over 2800MHz and leave mine, for now, at 2600MHz with 1.2625v. You'll get faster data transfer between many components. If you decide to overclock, same as with the CPU, I would recommend leaving it at stock voltage until it gets unstable and then up it by maybe .025v at a time. Probably best to do your own testing with different frequencies and see which gives you the best score.
Another OC to consider: I've read lots of people arguing both ways about raising the HT Link Speed for better transfer rates but I really didn't get a noticeable difference in 3D Mark 11 scores. Some even claim that raising the HT Link can lower speeds and scores.
