Philip Starck optical mouse erratic
Mouse
101
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Apart from ditching it completely, is there any cure for
a philip starck microsoft optical mouse behaving
verrrrrry erratically? I've tried changing the refresh
rate of the LCD monitor - to no avail. Any ideas?
Thanks in advance
What does the refresh rate of the LCD monitor gave to do
with the mouse settings (control panel)?
Not sure who Philip Starck is, but you should have a mouse
driver and be able to set some details. If it is a wireless
mouse you could have radio interference, weak batteries.
All mice have problems with bad wires, loose contacts
internally. And you could have a bad monitor or over-worked
video that isn't fast enough to keep up with the mouse.
Who is Philip Starck?
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
<mouse@roujan.com> wrote in message
news:077201c4900b$e4079a40$a401280a@phx.gbl...
| Thanks in advance
I read somewhere that erratic mouse behaviour can be
affected by screen refresh rates. Philip Starck is a
world famous designer who has developed a new microsoft
mouse. It comes with no drivers - it's essentially a
microsoft USB mouse. The monitor is an Iiyama Prolite
E431S and the video card a NVidia GeForce 2 MX/MX400
Perhaps I'll try to find an updated driver from microsoft.
Thanks for your help.
>-----Original Message-----
mouse
wireless
worked
for
>| Thanks in advance
Not sure which version is supported for this mouse, but here is a link
to the drivers page:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx
Nathan McNulty
> mouse
> wireless
> worked
> for
>>| Thanks in advance
You'd use Intellipoint 5.2 for the Starck MS Mouse.
However, Intellipoint isn't likely to fix your issues.
Does this issue persist on multiple computers? If so, it might be a
hardware issue.
To the original OP, if it is a hardware issue, you might want to call MSFT
Parts and Replacement at 1-800-360-7561
Make sure you have your mouse and proof of purchase on hand when you call.
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.com/default.aspx
"Nathan McNulty" <nospam@msn.com> wrote in message
news:e30xJ3LkEHA.1136@TK2MSFTNGP10.phx.gbl...
> Not sure which version is supported for this mouse, but here is a link to
> the drivers page:
> Nathan McNulty
>> I read somewhere that erratic mouse behaviour can be affected by screen
>> refresh rates. Philip Starck is a world famous designer who has developed
>> a new microsoft mouse. It comes with no drivers - it's essentially a
>> microsoft USB mouse. The monitor is an Iiyama Prolite E431S and the video
>> card a NVidia GeForce 2 MX/MX400 Perhaps I'll try to find an updated
>>>What does the refresh rate of the LCD monitor gave to do with the mouse
>> mouse
>> wireless
>>>mouse you could have radio interference, weak batteries. All mice have
>>>problems with bad wires, loose contacts internally. And you could have a
>> worked
>> for
>>>| Thanks in advance
