[SOLVED] Pin 20 at PSU end of 24 pin MB Cable missing wiring. Normal?
cyberfyber
20
Can anyone confirm whether Pin 20 of the PSU end of the 24 pin Motherboard cable should be missing?
It's an EVGA 650w Supernova G+
Posted at the EVGA forums and was told that it's normal now due to the 5V terminal that's not used anymore being intentionally left out.
Just want to be sure. Thank you.
If they told you its fine, then i think you are fine :)
Well, that could've been Joe Schmoe responding on the forum for I all know.
But, based on his mention I WAS able to hunt down related mentions.
One is from this very forum dating back to 2011. :)
