Been having ping spikes and loss for years now, but its been getting worse lately.
ISP: Cox
Connection: wired directly to modem @ 300 down 30 up. Idle network when testing.
Hardware: tested on Arris SB8200 and NETGEAR CM500, both brand new. Also tested on different PCs with high-end hardware and updated drivers.
Frequency: Ping spikes and packet loss at random times even during off hours (ie 3 AM on a Monday) which suggests this isn't a congestion issue?
Further info:
Downstream signal: View: https://i.imgur.com/gyxde49.png
Upstream signal: View: https://i.imgur.com/RASuOpl.png
Modem event log: View: https://i.imgur.com/a2nDkAf.png
Since the lag starts from the first hop, I'm thinking there's something wrong between my house and the demarc. Also the lag has gotten worse over the years so maybe a cable needs replacing? One problem is whenever the tech arrives to run tests, they rarely find anything because the lag is so intermittent. I appreciate any help.
ISP: Cox
Further info:
- replaced coax and ethernet cables to modem,
- Cox techs always say my signals look good, and that they can't act on a mere 1% loss. I point out the high ping spikes but they just point right back at the green checkmarks on the signals.
- Maintenance checked street lines and claimed everything is fine. They refuse to escalate any further.
- I also remember lagging using CenturyLink's DSL 60 down package.
