Hello everyone,
This is my first post here at tomshardware. I am looking to upgrade my Hp Pavilion dv7-3079wm with a SSD. My first question is what would be the pros & cons in your opinion to running 1 larger SSD or since I have two hard drive bays going with a smaller SSD for the OS and then putting a 7200rpm HDD in the second bay for storage of files etc. ? I havent really decided which way to go yet on this topic.
My second question is I want to make sure with either setup that I get the fastest SSD that my PC can handle. I understand that if I go for say a SATA 3 but my PC only handles up to SATA 2 speed then its pretty much a waste because my PC wont be able to make use of the full speed of the SATA 3. I have used CPU-ID, Belarc Advisor, and looked up info directly on my laptop based on the model and I haven't really come across a definitive answer to which SATA interface my PC has.
Some info I have gotten from these programs are:
Board: Quanta 363A 33.22
Standard AHCI 1.0 Serial ATA Controller
Chipset AMD 785G
The closest to a direct answer that I have come across is here:
http://www.cnet.com/laptops/hp-pavilion-dv7-3079wm/4507-3121_7-33873854.html
Under Storage it says for the Interface-Serial ATA-150
Serial ATA-150 is only SATA 1 so I am hoping that not right because I was hoping to at least have SATA 2 or 3. If thats what I have though then I guess thats what I will have to go with.
Curious though, when I run a system scan at Crucial.com it recommends SATA 2 SSD as being compatible with my laptop? If the cnet site is right then wouldn't getting a SATA 2 be overkill and it would be a waste of extra speed that my laptop could never make use of?
I know there are many questions I have in this one post but hopefully you all can help me out and point me in the right direction for this upgrade. If your doing something you might as well do it right the first time, right? I am also going to max out my system memory but I have that all figured out
Thanks
Chipset AMD 785G
Thanks
