How does everyone like this build? Any advice/critique would be greatly appreciated.
NOTE: these are all in Canadian dollars
Case:
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - http://www.newegg.ca/Product/Product.aspx?Item=N82E16811129043
Motherboard:
ASUS P6T Deluxe
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4268650&CatId=4068
Processor:
Intel Core i7 920
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115202
Video Card:
Nvidia GeForce 9800 GTX+
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814150314
Memory:
CORSAIR XMS3 6GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145222
Hard Drive:
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822148288
Optical Drive:
Some Samsung
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827151171
I do have some questions,
I was looking at this PSU:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817703009
or this one: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139006
but is there a better one out there?
my second question is: should I use water or air cooling? If I go with air cooling, all I'll have to do is buy 2 extra fans, bringing the total to 7....BUT...I understand that if I go with water cooling, it will be very expensive, but extremely effective, and I figure that since I'm buying a case that allows integrated water cooling that maybe I should look into it
as well, is it worth is to get the P6T Deluxe board with the extra overclocking tool a if I plan to experiment in overclocking in the future? (extra $40)
lastly, this is my first build, does anybody think that I should start less ambitiously?
EDIT: oh yeah, and I've been hearing a lot of mixed reception to intel's stock heatsink/fan that comes with the i7's...are they really that bad and should I get an after market one? As I've said before, I could also go with water cooling and get a water block for it instead
Case:
Motherboard:
ASUS P6T Deluxe
Processor:
Intel Core i7 920
Video Card:
Memory:
Hard Drive:
Optical Drive:
Some Samsung
