Hello Gentleman,
At the moment i have LianLi dynamic 11 Case, and at this point its starting to get too small for me after getting 3090 gpu and having to switch to 1600W power supply which is much longer than standard ones. Was looking around market and i cannot find any case that has support for radiator this size. My main concern is that at the moment i am in process of purchasing house and that always come with unexpected costs so idk how much extra money I can spare to finalize my system.
So to my question,
I have full custom loop on my i9 9940x, with 8cm https://www.aquatuning.at/wasserkue...phacool-nexxxos-monsta-360mm-radiator?c=25327 (12cm with fans on both sides) thick radiator from aquatuning, which is my main issue at the moment and i don't want to replace it since it keeps my CPU at 50-55°C in work conditions, 30°C idile.
So for now my GFX card is not water-cooled. and knowing that 3090 puts out huge heat inside chassis, my concern is how possible or good idea would be good to switch to new case, without having gfx card in water loop as well. Since idk how good airflow there is big cases is with my radiator case where all components are located. Anyone with experience can give me tip?
Should i wait few more months to spend extra 1000€ for full water loop on gfx card with both back and front water-cooled plates. or could some of your cases handle heat that gfx is outputting ?
I have changed stock thermal pads on 3090 as soon as i got it which got Vram temps from 100-105°C down to 85, but that's still a lot of heat that's going to dissipate inside chassis. Or can you recommend any other case that could fit this monster of radiator inside and still have spare fans inside to handle heat.
My Lianli case is modified to fit that radiator inside. And doesn't have good dust protection so that's additional reason why i want new case. hence having a cat its a huge issue and i have to clean it too often, picture attached https://ibb.co/Sn3t1FV
The cases i was looking at:
Any other suggestions?
So to my question,
- Phanteks The Enthoo 719, it looks like it could fit this huge radiator with fans on bottom of case but cant find anywhere exact dimensions
- Thermaltake The Tower 900. this one is a fit for sure, but issue is that front of case has only one ventilator, since all fans and radiators go in separate part of case. SO issue is heat dissipation from GPU and no way to vent it from front of case where all main components are.
- Phanteks The Enthoo ELITE this one is perfect for my needs, with issue of being 800-900€ at the moment
