Please help!!! first build help!!!!
s1lent
160
Someone Please help!!!
I have just built my first system. I have everything plugged in, hit the power button is starts up fine. I can get into the Bios setup Utility. I set the Dvd Rom to 1st to boot and then the Harddrive. I put in the Oem software and then saved it. Next it restarted and goes to a black screen and says" Reboot and select proper boot device or insert Boot media in selected boot device and press a key". I tried to hit a key, but it keeps coming up with the same message, over and over!
Hopefully someone can help!
my system is:
i7 920 2.66
Asus P6t (not the deluxe)
corsair xms3 6gb ddr3 (installed only 2gb)
corsair 850tx
samsung 1tb sata/300
9800 GTX +
HAF 932 tower
Please help me
YEs I checked back in the Bios and it shows the dvd drive 1st to boot. Windows Dvd--is that provided with the Mobo or vthe Vista software I bought?
