Hello you lovely lot.
I've just swapped out the stock cooler that came with my ryzen 5 3600x (Wraith Stealth I believe) and I have changed it for a RGB enabled Wraith Prisim. I followed all the steps and I'm 90% sure I've not done anything incorrect during the installation (pretty new to this PC building malarkey so cant be certain) I have powered up my PC and although the fan is spinning and lighting it's making a pretty horrendous noise. I quickly shutdown the PC in fear it was about to go up in smoke. I've taken a short video which you can see below. It definitely doesn't sound right but I cant see that anything is caught. It sounds as though the fan has a knackered bearing or the blades may be scraping the case. Is the fan completely borked or is it just not fitted correctly?
Video
Any help or suggestions I'd be super grateful. Worst case scenario I still have the old cooler so not all is lost I suppose.
Specs are as follows.
AMD Ryzen 5 3600X
MSI MPG X570 GAMING PLUS ATX AM4
MSI Radeon RX 5700 XT 8 GB
Video
AMD Ryzen 5 3600X
