Please help.. how many watts do I need for my PC
Chefboyardee83
This will be my first build.
Parts I am purchasing:
AMD FX-8350 Black Edition Vishera 8-Core 4.0GHz (4.2GHz Turbo) Socket AM3+
ASUS Crosshair V Formula-Z AM3+ AMD 990FX
CORSAIR Hydro Series H100i Extreme Performance Water/Liquid CPU Cooler
EVGA GeForce GTX 760 FTW 4GB 256-bit w/ EVGA ACX Cooler
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 1866
WD BLACK SERIES 1TB 64MB Cache SATA 6.0Gb/s
Silicon Power S60 240GB SATA III 6Gb/s Internal SSD
Corsair Carbide Series Air 540
I am thinking perhaps 750w would be fine but not sure.
Please advise.
Again, ignore this if you already have the parts ordered but I'd suggest something more like THIS for the main parts:
http://pcpartpicker.com/p/7z6GdC
- Asus Z97-A mobo
- i5-4690K (or i5-4460 if budget)
- EVGA GTX970 4GB ACX 2.0 or similar
- CM "EVO" (or Noctua NH-U12S if budget permits)
I can't say exactly since I don't know your total budget but even if you have to get an i5-4460 and slightly cheaper motherboard you'll have a far better system this way (i5-4460 + GTX970 vs FX-8350 + GTX760).
Note that you don't need an expensive CPU cooler for modern Intel CPU's.
Above is correct.
*However, if you haven't yet built the PC I would strongly suggest basing it on an i5-4xxx Intel CPU instead. I might even be able to build something for about the same budget that includes an i5-4xxx CPU and a GTX970 4GB graphics card since there are parts you could swap for cheaper components if you want to focus on the core gaming parts (CPU + Graphics card).
Winly
please take a look a the link I posted. A PSU its a very imporant part of a system, you dont want to go cheap with.
By the way, the EVGA is a great PSU "Tier One"
- Asus Z97-A mobo
